Soup Bowl Mods...
The hat and flex elbow are stock Durango 5.9 Magnum parts, the aluminum tube and filter are aftermarket bits. I lucked into those at the junkyard, I was going to use a Ram pickup filter housing which sits on top of the inlet and uses a rectangular filter.
You could start with the Durango hat and flex elbow, then a PVC pipe and K&N filter wherever is most convenient. Mine is sitting where the a/c compressor used to live, my truck doesn't have a/c so that went away.
In cab noise isn't bad, I have very little sound deadening yet can actually hear myself think now. You truck would probably be near gasser noise levels.
79 Camper Special
06-21-2009 10:23 AM
jorgholio
17
01-07-2008 09:09 PM
eric777
12-20-2006 09:27 AM
