PCM diode NO START - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
PCM diode NO START
Old 11-10-2013, 12:33 AM
flatbedpower flatbedpower is offline
flatbedpower is starting off with a positive reputation.
PCM diode NO START
ok so im new to diesels but my truck will not start. it is a 2000 7.3 6 speed dually. i recently was messing with the truck and pulled out the pcm diode and as i was putting it back in something sounded as if it grounded something out. i know its stupid to mess with electrical while it was on. my wts light still lights up. i would like a diagram on where the wires go after the pcm diode and how to test all of the components. it did run for about 5 mins after and ad some white smoke. and a code came up that said injector pressure wasnt at desired pressure or something. code p1211. an help would be appreciated thank you.
Old 11-10-2013, 01:06 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Were the keys in the ignition when you restored power to the PCM?
Here is a good no start diagnostic guide. Scroll down to the 7.3 write up.
Diesel Diagnostic information for Powerstroke 6.0, 7.3, IDI 7.3 and 6.9 L, by Oregon Fuel Injection
Old 11-10-2013, 05:14 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Have you checked the pcm diode to make sure that it was not
compromised?
Sean
Old 11-10-2013, 09:39 AM
Yes there was power when I put the diode back in the truck. I know not exaclty what I was supposed to do. Lol
And yes the diode checked out good and just to be safe I switched it with the a/c diode after checking both of them. Im looking into that link with diagnostics that shake-n-bake posted. I appreciate the help. Anything else would be great.
Old 11-11-2013, 05:51 PM
Ok so I spent all day yeaterday troubleshooting. And I have gotten nowhere. The p1211 doesnt come up anymore. And it still doesnt start. I went through many wires and sensors. I also had another 7.3 to come over and try to help but he was stumped as well.
Old 11-11-2013, 06:05 PM
Yahiko's Avatar
What tool are you using to scan with?
I am not sure with the 7.3 But and this
is a guess. Can you see live data with your scan tool?
With that you should be able to see where your getting
the no start from.
Sean
F150 Starter circuit electrical: burnt ECM, 2 starters, 1 starter relay bl1989 1987 - 1996 F150 & Larger F-Series Trucks 4 07-07-2016 04:02 AM
PCM Diode keeps blowing kbarbee95 1999 - 2003 7.3L Power Stroke Diesel 9 02-02-2015 08:00 PM
5.4l not cranking (I messed up) mojs Modular V8 (4.6L, 5.4L) 5 12-04-2012 11:03 PM
2001 F150 5.4 Triton Won't Crank! 200154tritonguy 1997 - 2003 F150 4 06-22-2010 02:45 PM
EEC Power Diode pchristman Electrical Systems/Wiring 5 02-22-2006 11:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
