How do i flush my Power Steering?
Guaranteed no air that way and since the m/c is so short the tubing isn't such a big deal.
Josh
Best way I have found on motorcycles is use clear tubing and pump out all the old fluid, then run the tubing into the reservoir and just keep pumping the clean new fluid in a continuous loop.
Josh
Josh
Iv Done Cars Like that For troublesome air bubbles seems like you can really get the Flow Going and Pull the Air out
That was after pretty full Brake system come apart
You just had to remind me. I have all the supplies for that and the
transmission dump and fill with a new remote filter. I just need to
pick up some power steering fluid.
Also today I picked up a seal driver for my ball joint project. That
was the last tool I need for that project. Time to start getting parts.
My big problem is it keeps sprinkling on me.
Sean
BTW : I have used a mityvac in the past on Rangers and on Explores and they do a good job.
Sean
Mityvac won't completely remove the air bubbles on the clutch master with the way it mounts at an angle.
Josh
It's an all metal pump. I did pick up a larger catch bottle 6oz does not
cut it on a Ranger let along a Superduty.
One thought on the trans unit because we have a drain I don't see the problems
that the people that have the pans that don't have a plug have to deal with.
I always hated doing that type of fluid change. The driveway got more than the pan
it seamed most of the time.
Sean
Look up the Silverline
http://www.lincolnindustrial.com/Cat...0_Brochure.pdf
It does both pressure and vacuum.
Sean
Sean
#29
IMHO, Mercon V syn. is the only way to go. Ford says Mercon V and doesn't specify syn. I also installed a filter on the return line. Cheap Ins.
Magnefine #R038M. Less than 20 bucks at www.emergingent.com/magnefine. It has a filter and magnet designed for auto trannys. Will probably be good for the life of the system because of its capacity.
#30
