Fuel, where did you go? - Ford Truck Enthusiasts Forums
Old 11-09-2013, 09:04 PM
Morgan's F-250 Morgan's F-250 is offline
Morgan's F-250 is starting off with a positive reputation.
Your thoughts please,
Can the manual tank switch go out? The one, on the floor, in the cab.
My switch has a lot of play. It spins rather freely.
Answers??
Thanks in advance
76' FE 360 Camper Special XLT
Old 11-12-2013, 10:46 AM
TinyWonder's Avatar
TinyWonder TinyWonder is offline
TinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to beholdTinyWonder is a splendid one to behold
My suspicion is that yes a fuel valve could fail.
I think you would smell/see a fuel leak of that magnitude.
In years past, I owned a Chevy pickup (i've already done lots of therapy for that offense) with a manual tank switch. The second tank was installed by the previous owner and didn't include all of the factory piping/tubing. If the main tank was full and I was running on the secondary tank the excess fuel that the pump provides to the engine would route back to the main tank. When it got overfull it would just spew out the side of the truck.
Again, if you're losing a lot of fuel you should see it or evidence of the spill.
Do you have a locking fuel cap? Could someone be stealing the fuel from your truck?
Old 11-13-2013, 02:19 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Ive owned a LOT of old trucks with the manual tank valves on the cab floor, NONE spun or turned really easily......If its leaking seriously, you should smell it when you get anywhere near the truck
Old 11-13-2013, 02:24 PM
iggybob44's Avatar
Oh, and the valve handle is inside the cab, while the actual valve will be on the underside of the cabs sheetmetal in plain sight, where you can inspect it........the valve and its handle are brass as i recall, and the handle and the actual valve are keyed alike with either splines or a "D" shaped shaft to mate with the valve handle, then secured with a screw......the shaft or handle may have worn, to where the handle itself is turning upon the actual valve assembly.....
Old 11-18-2013, 06:27 PM
Thanks for your help RE: Fuel, where did you go
I've been to busy as of late; work, work, work, but the notion that the manual tank lever has failed, is a good place to start.
Upon closer inspection there is no indication which position ie: indicator arrow??? controls AUX or MAIN tank.
Ah!! Yes, Thank you. Followed by yet another question.
Morgan's F-250
Door switch bracket mesurements CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-16-2014 08:58 PM
Overdrive Switch ExtrmZ 1987 - 1996 F150 & Larger F-Series Trucks 11 10-07-2014 08:33 AM
High beam switch not locking on Big-Red-Lariat 2009 - 2014 F150 4 06-22-2014 03:05 PM
headlight switch question. 86ford302help 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-01-2013 01:03 AM
Anyone ever had a bad ignition switch? yankeerebel 1973 - 1979 F-100 & Larger F-Series Trucks 17 10-22-2013 06:51 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
