need help on 89 150
need help on 89 150
I have a 1989 f150 the truck has sat for 7 years and I got it running really well except when I go to give it large throttle like getting on the interstate it just makes funny poping noses and will not pick up speed but it idles like it should checked fuel press and its about 35 when I unplug the regulator vac line it goes to 43 and seems to run better and throttle better is my fuel press regulator in need of replacement
no I have all new cap rotor plugs and wires the only thing I thought that was odd is there is no fuel filter that I can find the lines go from tank to switch valve to pump then to engine and the engine is a 5.0 im thinking about eliminating the switch valve and replacing it with just an in line filter and also eliminating my rear fuel tank my return lines I have a piece of plastic tubing that will hook them back together
sufferingant
09-23-2010 07:57 PM
