48-50 F1, F2 & F3 Cab Variations
I'd like to know the following information regarding the cabs on the 48-50 Ford pickups:
1. Are the dimensions/size of the cab on the F1, F2 & F3 the same or do they vary? I believe that the F1, F2 & F3 all had the same size cab.
2. If they vary, does anyone know where, what or how much the cab varies and on which models?
3. I believe that the emergency brake on the 48-50 is a handle bolted to the firewall on the left side of the cab up under the dash. My mechanic thinks that the 48-50 Ford pickups had a handle through the floor mounted right next to the floor shift. I'm thinking that might be true in the larger/bigger models but I don't believe there was an E-brake handle mounted next to the shifter on the F1, F2 & F3 in 48-50.
Can some of you please help us on this?
Thanks very much,
Les
Thanks very much,
Les
Thanks very much,
Les
Thanks very much,
Les
My '51 F2 has the stock configuration of a transmission band-style of parking brake. The handle comes up through the floor next to the shifter.
It might be because the truck was ordered with the 3-speed heavy duty transmission.
tom
loudfords
11-18-2004 11:25 AM
Ford51
10-04-2004 04:16 AM
Joe51f1
04-21-2003 05:00 PM
