fuel leak leaking down starter - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-09-2013, 02:21 AM
pilgrimbizket's Avatar
pilgrimbizket pilgrimbizket is offline
pilgrimbizket is gaining momentum as a positive member of FTE.
Well I noticed I had a fuel leak, its leaking down the starter. I ordered an oring kit. Now even with all new o rings I'm still leaking fuel. I also replaced the 4 hoses.
So what is another common leak point in the valley of death.
Old 11-09-2013, 06:19 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Check where the fuel line goes in the back of the head. There are square cut rubber o-rings in those fittings that sometimes leak.
Old 11-09-2013, 07:22 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
check the pump itself
Old 11-09-2013, 03:31 PM
Ford4Life7.3's Avatar
Ford4Life7.3 Ford4Life7.3 is offline
Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.Ford4Life7.3 has a good reputation on FTE.
x2^ on what these guys said. Check the rear of the pump itself where the lines come out and the banjo bolt threads in. Also, check the drain valve on the fuel bowl, its possible it got turned partially to the drain position.
Old 11-09-2013, 05:27 PM
Hussler's Avatar
Hussler Hussler is offline
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Quote:
^ x2 ^ on the pump. It has a weep hole directly underneath the passenger side of the pump body. Extremely hard to see leaking real time. Another common fuel leak is at the fuel filter restriction sensor, right where the wire plugs into the sensor as shown here ...
Old 11-09-2013, 09:24 PM
Thank you for all the responses. Im out enjoying the pheasant opener. I will check on when I get back.
Quote:
Does anything need to be removed to acces these.
I plan on checking these first since everything is put back together already.
Old 11-09-2013, 09:56 PM
Best part of deer season ending, is that upland game starts
No, nothing has to be removed, your just looking for fuel around the fittings.
Old 11-11-2013, 07:47 PM
The pheasant hunting was awesome. Hunting wild birds in southern california near the mexican border epic.
Im glad I read that I was going to remove them. and physically inspect the orings.
Old 11-11-2013, 08:33 PM
Never hunted down there. Im a northern CA boy lol.
Old 11-14-2013, 11:01 PM
Well its my fuel pump that is bad everything else looks good.
Bummer part is my truck is a Cali model with the darn fuel dampner. Anyways I found a great thread on FTE, informing me I dont have to pull the turbo to get at this mess.
http://www.ford-trucks.com/forums/61...placement.html
^^ If anyone else is intrested.
So I have a new fuel pump and new washers for the banjo bolt. Am I missing anything else.
Wish me luck Im about to loosen fuel lines and get at the Dampner then the Banjo bolt.
Goal is to get the pump out tonight!
I have tonight and tomorrow night to handle this. Come Saturday morning I need to be hunting pheasants. And Im not craming in my lil Colorado again. UGH!
Old 11-14-2013, 11:03 PM
You don't have to use a Cali pump
Old 11-14-2013, 11:11 PM
I thought I read somewhere the fuel dampner does something with the split shot injectors. Not sure though.
Lol looks like I have to cut a wrench down to get at these fuel lines. And move the downpipe back.
Old 11-14-2013, 11:12 PM
Or maybe a crowsfoot will work
Old 11-15-2013, 01:08 AM
Is there a difference between regular pumps?
Because looking at the pump it appears there something threading into the back of the pump. And that is where the dampner goes. Suggesting its that peice inbetween the banjo bolt and pump that differs between cali and federal trucks
Old 11-16-2013, 03:05 PM
This is so un real
what a horrid design I can not for the life of me get this banjo bolt back in. there
I mean is this why people install E fuel.
This is definitely worth 1k not to ever do again.
Damn California trucks
oil leak with my 2001 7.3 btenopir77 1999 to 2016 Super Duty 1 12-16-2016 12:27 PM
Oil Leak Passenger Side idisam6.9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 05-30-2016 06:23 PM
fuel leak! erich545 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 11-12-2015 09:16 PM
7.3 idi oil leak HELP firegod75 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-03-2015 03:29 PM
Fuel leak from back of engine!! 1reddawg12r Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 02-15-2012 08:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
