Has anyone else replaced the actuators on the rear door locks? Both of my rear door locks are bound up pretty hard to the point that I can barely open them with my fingers. I haven't been able to open them with the lock switches for quite some time. For now I would just like to find affordable replacement actuators. A couple local Ford dealers want about $250 EACH and I haven't had much luck online. Does anyone have a source for these online?
I can't really see them using different ones in the rear, but ya never know. I'm gonna find out on of these days if they are the same. I need to pull some from some doors I have. I have a problem with one of my back doors, and a buddy does too.
If I can find some compatible actuators I'd like to have a remote entry system installed.
I think the rear actuators are different but I am not sure. Part # for rear doors from ford very expensive. 26594
Part # for front doors 218A42 not so expensive.
They are very different.more like the older fox mustang ones but high torque.I retrofitted a mustang unit in but it did not have the poop to pop..remove the actuators ant the locks will free up..no power but I'm not spending 600$ for power locks!!!!
Per Ford the correct part # for my truck is E7TZ-3526594-A. When I searched online for "Ford door actuator" I found a similar part # for an Aerostar that is a hell of a lot cheaper and looks identical, #E69Z-1126594-A. No clue if they are interchangeable.
That pic will be just like fox mustang,tempo,ranger...pretty much anything BUT cc. Try something and see if you can get it to work. I had no luck. I'm kind of starting to think my rr latch may be jacked up.
Looks like when were in the junk yard searching if we run across a cc we should look to see if the actuators are there and put up for later. I have one that acts up every now and then.
