20" Light Bar Wiring to Bright lights
#31
I'm with ya on changing out everything for LED. At home I'm replacing all of my recessed lights with Home Depot ecosmart (Cree) lights. Instead of 65watt incandescent it's 10 watts.
At one of my stores I swapped out canopy lights. They were using over 500 watts per fixture, (30 fixtures) to 110 watts per fixture. I save roughly $900-$1000 a month on my electric bill.
Assuming you meant you are saving $900-$1000 on just the canopy lights replacement alone, you are leaving them on for 522 hours a month or an avg of 17 hours a day (if my math is correct).... is this a gas station?
That's great savings!... The question is what was your initial investment?
I also swapped out all the recessed lights in my house (~30 fixtures) for the 10W Crees from Home Depot. Luckily I bought most of them when BGE (local utility supplier) was subsidizing their cost ($25 each rather than $35 each). I doubt I will see the energy payback in the time that I own the house, but I hope to see the payback given their longer life expectancy (I should never have to change them....ever lol)
Back to the OPs original question. I currently have my light bar connected to one of my upfitter switches but I don't like that configuration. I often find myself cruising down back roads with my light bar on, when I see a car coming in the distance I have to lean forward and switch the upfitter off, which is not a natural motion.
When I can find time, Ill be interlocking a relay so that the light bar will only be "on" with the upfitter switch "on" AND my hi-beams "on." This way I can activate the light bar with the multifunction switch, but also lock out the bar with the upfitter.
#32
another slight hijack..
I would love to do a 20in bar, but we have front license plates.
so have been considering 2 4/6/8 inch bars, one on each side of the plate.
I like my fogs, so won't replace those.
they also make a plate that fits behind the license plate, with a mounting surface on top. I just hate to have the light bar exposed like that.
anyone done the 2 lights?
#33
2011-2013 Ford F-250 / F-350 Super Duty XLT / Lariat / King Ranch - Torch Series LED Light Grille (Will not fit base model XL work trucks w/ utility grille or models equipped with towing package and transmission cooler) (For off-road use only) [63154
Rigid Industries LED Grilles, OE LED Grilles, Ford LED Grilles, F-250 / F-350 LED Grilles, Super Duty LED Grilles
There is a third company that just came out with one, but I can't find it at the moment.
I'm not a big fan of the Rigid grille, it looks a little too home-made.
The T rex would look good with out the giant "Xmetal" emblem IMO
Expensive, but if you don't totally love the super duty grille, it could be an option.
#34
Another few options I just came across last night:
rigid, 729 + the lights?!..
#36
M&R used to sell a 6" Elite mini light bar that two would fit perfectly, one on each side of the plate. You would have to fab a bracket but there is plenty of room for that.
I wound up using them for another project because the 30" bar rendered them un-necessary, but they are an option.
Here are a few pics from the M&R website that show them on a Raptor but up near the "A" pillars.
They are not showing up on the website right now but give Michael a call there and he can probably tell you when they will be back in stock. He's a good guy with great prices.
Home - M & R Automotive - Custom FORD Raptor and Wrangler JK LED Light Kits
#37
#38
#40
It is mounted behind a T-REX mesh black grille.
#45
