Winter's coming: diesel additive
As for the cost of the PSDK, it comes out almost being next to nothing +or-. I see at a minimum of a 1 MPG increase using it.
I also tried using the Ford Motorcraft equivalent but the cost and ease of finding the Diesel Kleen makes it my preferred choice.
Good call...seems obvious to me, but maybe not everyone.
Usually next to the white bottle there will be the gray bottle. I don't know anyone that uses the gray.
In fact when I got my first diesel my son told me to use only the white, and at least once a month put it in four wheel drive with the auto hubs. A little off subject, but that was the way he said it every time.
White bottle (includes antigel/winterizer)
Gray bottle (no antigel/winterizer)
Depending on your local, you may not see the white bottle Pretty hard to find it in Arizona because it's not needed. Just depends where you are shopping and where you live. Gray is used more frequently with summer diesel and white for winter diesel. Doesn't mean you will destroy your engine if you use the gray bottle in the winter or white in the winter.
So I have been running the Motocraft Red topped Cetane booster additive (scored a case on the cheap). It looks like motocraft also offers a black capped "anti-gel and performance booster". All of our ULSD out here is "winterized" from the pumps. Should i switch to the black top anti-gel or stay with red topped Cetane booster in the winter? Or should i just switch to power service white/gray when i run out of my cheap case of the ford stuff? Are you running power service because its better than the motocraft stuff or because the price is right?
By the way, I love this forum. Have lurked for quite a while but decided to sign up tonight. Great resources here so far!
Welcome to the forum kd !
back to the subject at hand:
I've rarely used any additive,
BUT we are in the DFW area
and I've only been driving ford deezles since 2002 or so...
never had an issue with any of our engines except for the one batch of bad fuel I got in my excursion... and no amount of additive would have helped 40% water
I do have a question for you that buy the gallon bottles....
is there a concern with it sitting in your garage for months after it's opened ?
