Tps?
Tps?
97 f250 460
It all worked fine until, I replaced my bbk throttle body tonight (with a new exact same one) and now it shifts bizarre, 3rd seems like 2nd and visa versa, idle all over the place
I didn't unhook the battery when I unplugged the tps and it really only can go in one way. Bbk has a long set up for the tps installation but it worked fine with the 1st bbk TB the way I installed it. The only reason I replaced it is because the linkage springs were messed up and it was still under warranty
I'm thinking the tps is about all it can be? Any thoughts ?
There should be no reason to bore out the holes. If the output is wrong verify the throttle blades are closing properly then replace the tps if required. As long as the closed voltage is between 0.6 to 1.0 VDC your good, there is no reason to set it to a specific value in that range. Also verify the output is linear to ~4.75 at full throttle.
I'll do that. It just bugs me that it all went south after only putting on a new TB
This has been the upgrade year for her - new trans at ford dealership, banks headers and exhaust, 4"skyjack lift, nitto grapplers, all tune components and more
Hope we getter figured out, I use the truck for a lot of personal stuff - fishing (pulling boat to river) and hunting mostly
Think I figured it out
1st my back probing skills are bad
Checking ohms on tps found it doesn't work when hooked up to the bbk TB
By the time you screw the tps on to the bbk TB it's cocked a little and binds up
Might be able to make a thin gasket to hold it off the TB a little?
Or just go back to the oem TB?
WestyNaut92
01-21-2017 11:58 PM
