How To: Headliner - Ford Truck Enthusiasts Forums
How To: Headliner
Old 11-07-2013, 08:43 PM
BiGGreen350's Avatar
BiGGreen350 BiGGreen350 is offline
BiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant future
How To: Headliner
well today i had to redo the headliner for the 84, figured this question comes up a decent amount so a hhow to could help, its super super easy, i beleive anyone of you should be able to do this,
anyways
Materials needed:
-first off, a crappy headliner that needs replaced,
-Clips, like chip bag clips, i visit moms kitchen for those when i do headliners lol but a wifes kitchen will sufice, im only 18 so im not married
-electric or cordless drill
-a flap wheel attatchment for said drill
-new headliner material, i visit local upholstrey shop i got 2 yards worth
-spray adhesive, got also from my local shop
-razor blade
1st things first, go outside, this will make a huge mess, like get put in the doghouse for a few weeks if tried inside
set up a table, put the headliner on it, and pull the old headliner material off like so, it will not take the foam off with it
you will end up with a pile of this
leaves you with the headliner board looking like so
take the drill with the flap wheel and begin taking the foam off the cardboard, the wheel will not hurt the cardboard just be careful around the edges, on most of these i have done the area around the sun visor mount is usually pretty thin, both sides on this one were already broken off, simple tape will fix that issue, not a big deal just make sure you re attach it later well
this step took me 30 minutes with the drill to remove the foam
next step clean off your table and set the headliner board on it, then lay the new material out on it evenly where you want it, you will have excess if you get 2 yards worth
next once its where you want it, place the clips around the outter edge on one half of the board like so
now fold back the unclipped side
now spray your adhesive down on both the board and the foam backing of the material, make sure you do both!
now i pull the side you just sprayed straight up with one hand, then walk it back slowly and use my other hand to smooth it out flat on the board, here a second set of hands could be helpful
now let that side sit a few minutes, then remove the clips, place one on each side at the edge of the section you just did, then repeat on the other side exact same process
then remove the clips, take the razor, trim your sides, and cut out hole for dome light and visor. cut outs for dome light and visor mounts do not need to be perfect along with the outer edge, the trim hides it anyways
and walla, a course in headliner 101
installed it later tonight
Old 11-07-2013, 09:19 PM
JayzDaddy's Avatar
JayzDaddy JayzDaddy is offline
JayzDaddy is gaining momentum as a positive member of FTE.JayzDaddy is gaining momentum as a positive member of FTE.
Cool deal. Cmon by and do mine.
Old 11-07-2013, 09:23 PM
Tim's83F100 Tim's83F100 is offline
Tim's83F100 is starting off with a positive reputation.
Your headliner looks great! Good job on the write up and the pictures.
Old 11-07-2013, 10:01 PM
Sac79's Avatar
Sac79 Sac79 is offline
Sac79 is starting off with a positive reputation.
How is the headliner attached in the cab? Mine doesn't have one, would I be able to fit one without other mods? Nice job by the way...
Old 11-08-2013, 02:59 AM
Quote:
no modifcation needed, just the dome light visors and surrounding trim hold it up,
And thanks guys
Old 11-08-2013, 04:49 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Very nice.
Rep's for the writeup.
I just did mine a few weeks back.
Scraped the foam off with a putty knife.
It looks like that flap wheel would take some of the tedium out of the job.
Did it leave a mess of foam dust?
Did you just use masking tape to fix those broken corners?
I put mine back with helicopter tape and wicked some CA (Crazy Glue) into the broken cardboard to stiffen it up.
Maybe I just went overboard???
Old 11-08-2013, 08:04 AM
Quote:
Originally Posted by ArdWrknTrk View Post
Very nice.
ouch i could not imagine doing that with a puddy knife, that would suck!!!
heck it is even tedious holding the drill that long with thee flap wheel on it but nothing too crazy.
yes it does make a big mess, thats why i make sure to do it outside lol
on this one i used a combo of masking and electrical tape, on two other ones i have done i used duct tape,
Really doesnt matter which method you use as long as it firmly re attatches it before the new material goes on
Old 11-08-2013, 08:21 AM
pedant
It only took me 15-20 minutes to scrape it all off.
There were 'crumbles' but no airborne dust doing it by hand.
I quickly went over it with a scouring pad when I was done.
It's SO nice not to have a saggy, stained and dented headliner anymore.
I bought a kit on Ebay.
Do you mind if I ask how much the material and glue cost you, locally?
Old 11-08-2013, 09:29 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Great post - sticky?
Great thread, BiGGreen350! I, too, gave you a "rep"!
Chris, [ctubutis], is this worthy of becoming a sticky?
Old 11-08-2013, 10:23 AM
lol never worry about askin me price, i dont mind tellin, i had 19 dollars in the fabric and 7 dollars in the glue, so 26-30 dollars for a headliner for people who may not have certain supplies
Old 11-08-2013, 10:24 AM
Thanks and also for the suggestion hahaha
Old 11-08-2013, 09:23 PM
txson93 txson93 is offline
txson93 is starting off with a positive reputation.
Great looking job, Big Green. The pics and explanation are great. The headliner in my '98 is in pretty bad shape, caused by too much hot weather. I had priced getting it done professionally, guy wanted $90. I can do it myself now.
Kenn in Texas
Old 01-27-2014, 12:58 PM
Quote:
Kenn in Texas
no problem, howd it turn out?
Old 01-27-2014, 01:43 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Reps to you for that! Good job.
Old 01-27-2014, 02:13 PM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
Nice write up and pics. Thanks for sharing. REPS
40 tonner panel build willowbilly3 1947 and Older Ford Trucks 71 01-24-2016 04:01 PM
What are these willowbilly3 1947 and Older Ford Trucks 2 01-04-2016 09:37 PM
Some tedious differences on 40 and 47 doors willowbilly3 1947 and Older Ford Trucks 4 12-03-2015 07:06 PM
Odd serial number question willowbilly3 1947 and Older Ford Trucks 6 11-19-2015 09:12 PM
Mistress Build Thread martin72 1994.5 - 1997 7.3L Power Stroke Diesel 113 04-05-2015 09:17 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
