2015 Superduty
#31
#32
I guess coming from most of the rest of the automotive world you don't see redesigns every couple of years necessarily. Jeeps (Wranglers) tend to go in 10 year cycles, for example, the first Miata was around for almost 10 years, etc.
#33
Why, what needs to change? What's wrong with it?
Quite frankly, I'd love to see the SD and the F-150 go back to the same look. Naturally the SD would maintain it's size and capability but it would look like a huge F-150.
#34
#35
#37
#38
I'd agree with the right approach and no frame that sits way lower than the body.
#39
Looking at thepg reports from f150 ecoboosts i dont see an ecobost of any size in the sd making much better mpg than the 6.2. So the market would have to be for better towing/power which runs it up against the 6.7 which is also hard to compete with.
Anyone see a ecobost of 400+hp in a 8000Lb brick shaped superduty making much over the 14-16mpg the 6.2 gets??
#41
In contrast, my uncle just bought a 2013 6.2L F150 Platinum; at 65 MPH he shows 15-16 MPGs with the same 3.73 gears that I have. That truck is rated at 16 MPG highway.
That makes my truck 30% more efficient than a similar 6.2L truck. How is that NOT much better?
#43
#44
No if you look at mpg reports the eco has a big advantage at curb weight. As gvcw goes up the eco and 6.2 get alot closer mpg. Since the 3/4 and 1 ton will have higher average gcvw the advanTage of the eco would be less!
#45
But my F150 with a 500 lb motorcycle in the bed while towing a 3,500 lb trailer gets as high as 15 MPGs on the highway at 65 MPH. The same trip on my empty Excursion yielded 12.5 MPG with the old V10; most reports suggest that the 6.2L isn't much better than the V10.
No doubt efficiency goes down as boost goes up as the engine retards ignition timing to avoid detonation, but a larger 5.0L engine would have the displacement to not require much boost at all to maintain speed. And if the 5.0L saw the same power increase as the EcoBoost did with the twin-turbo treatment it would turn an F350 into a rocket ship!
