Back-up camera - Page 2 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Back-up camera
Old 07-17-2014, 06:47 PM
gman97005's Avatar
gman97005 gman97005 is offline
gman97005 has a good reputation on FTE.gman97005 has a good reputation on FTE.
Quote:
Originally Posted by WarrensE350 View Post
So I put a backup camera on Bubba, and it's pretty cool. However, the issue is that while the camera outputs what it assumes is centered behind the van, it's actually mounted on the licence plate well in the door so the image is off center by a foot or so. It's something I will compensate for over time if no other simple mounting location is possible, but has anyone else installed one in the rear center? How did you do it? Mine's specifically a 97 E-350.
remove the LR door panel and drill hole through door skin as close as permitted to the edge the door, the hole should be just big enough for the lens of the camera to fit through snugly, fabricate two 90 degree angle brackets and attach one to each end of the camera bracket then drill 2 holes through the inside edge of the door and through the corresponding angle bracket, use rivets and gun to secure, run wiring and reinstall door panel..
or..
mount it on the roof and cover it or maybe along the inside edge of the rear window, the trick is finding a way to rotate the camera inside the housing allowing you to position the bracket in a manner that suits you best
or..
modify the existing mount so the camera is at the inside edge of the license plate instead of the center, get creative..
Old 07-18-2014, 07:58 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
GMan you have any photos of your installation---that sounds quite interesting.
Old 07-24-2014, 10:37 AM
WarrensE350's Avatar
WarrensE350 WarrensE350 is offline
WarrensE350 is gaining momentum as a positive member of FTE.
Quote:
or..
or..
The camera I have now was very inexpensive, and while it's functioned satisfactorily so far without issue, I'm hesitant to drill into the van to mount it because I don't see it lasting 10 years and I don't want to deal with another round of surgery if I can't find a similar sized replacement. I've gotten used to the offset with it mounted in the plate well, to be honest. It does give a good view of what's behind the van, so it serves its' purpose well as-is.
Old 07-24-2014, 03:12 PM
jimandnena jimandnena is offline
jimandnena is gaining momentum as a positive member of FTE.
I agree with you, Warren. I bought a one of these for the wife's Explorer
Robot Check Robot Check
And it worked well enough that I bought another when I got the '88 Club Wagon. I do not use the rear doors much so I fastened the camera to a piece of pipe strap and stuck it under the weatherstrip on the left side rear door. The view is as close to center as needed and just above the step bumper.
One issue, vehicles are a LOT closer than they appear on the screen.
jim
Old 07-25-2014, 07:18 AM
JWA's Avatar
JWA JWA is offline
Jim that's an exceptionally affordable back up cam set up---thanks for that link.
I'm curious though about Pyle's claims of its IR capabilities---any impressions or observations about how well it works in low light situations, aka "dark" ?
Old 07-25-2014, 09:48 AM
The price for the 2nd one was even better, JW. After I got it delivered, Amazon emailed that they had refunded my money?! Since I hadn't requested a return, I checked with the company and they emailed that I had received a discontinued model so they refunded my money and did NOT want the unit back. My first ever, win-win situation. haha
I'm having problems posting photos for some reason but the daytime view is in my gallery:
Rear view camera next to mirror. by jimandnena - Ford-Trucks
At night, with the backup lights on, I can see the house across the street from us. I don't know about IR, usually there is some IR LED light source on the camera and I don't see that anywhere. This is a cheap model but the one on the Explorer has been there 4 years and still working.
jim
Old 07-26-2014, 06:51 AM
JWA's Avatar
JWA JWA is offline
Thanks Jim---I keep forgetting we have rather bright and effective back up lights on our vans!
Old 07-26-2014, 03:17 PM
I know! The first night after installing the camera, I started to back out the driveway and thought someone had pulled in behind me. Almost too much light for the glare but once I figured it out, no problem.
I'll try to stay up past my bedtime and get some night photos. The rear view mirror is still better for daytime driving but when backing up, the camera is best.
I thought about installing additional cameras like the stealth fighter uses but it seemed a little overboard. :-)
jim
Old 07-27-2014, 07:36 AM
JWA's Avatar
JWA JWA is offline
jim
As we've discussed if its "overboard" then its just about right?!
F-35's make the Millennium Falcon look like a Model T, only quite a bit more I think?
Love to see the night time photos when/if possible. If you can't stay up late just get up earlier?
Old 07-27-2014, 10:48 PM
Got one! I tried to get the same size as the daytime photo for comparison. Working on the Darth Vader/Ironman helmet now. :-)
Rearview camera by jimandnena - Ford-Trucks
jim
Old 07-28-2014, 06:50 AM
JWA's Avatar
JWA JWA is offline
Those are quite respectable images Jim---even at night that camera and display seem to well worth their cost AND are effective too!
  #28
Old 07-29-2014, 11:14 AM
katoranger katoranger is offline
katoranger is starting off with a positive reputation.
I installed a Pyle brand backup camera on my van. It looks just like the one George has. Mostly wanted it for hooking up trailers so that I could see the ball.
Mine is mounted to the top the receiver hitch. I could a chunk of treated 2x4 and attached it to the crossbar part of the hitch and then used a couple screws to mount the camera to the 2x4. The camera sees the trailer ball and I can now back right up to a trailer without getting out. I don't really need it to see out the back since I have windows all around.
  #29
Old 09-03-2014, 12:47 AM
jmo1112 jmo1112 is offline
jmo1112 is starting off with a positive reputation.
Sorry to resurrect this thread again, but I finally got around to buying a backup cam...the flushmount one, to be specific. That said, how do you secure the camera to the car?! I haven't drilled any holes yet, and I've googled the install for these things, but there are literally NO install tips or videos available for the flush mount kind. I'm just really confused on how this thing stays mounted in place.
Any ideas?
  #30
Old 09-03-2014, 06:07 AM
JWA's Avatar
JWA JWA is offline
Exactly which model or type camera did you buy?
Rear view camera wiring assistance request. jonrjen 6.7L Power Stroke Diesel 26 10-30-2016 04:03 AM
Need help deciding on a backup camera Apocalypse Excursion - King of SUVs 9 08-24-2016 06:44 PM
adding factory backup camera to back of camper ProActive Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 7 07-05-2016 08:19 AM
Backup / Rear view cameras - what are you using? ShawnQ Excursion - King of SUVs 14 05-21-2015 06:29 PM
Backup Camera JVErnie 1999 to 2016 Super Duty 3 02-24-2015 08:57 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
