1967 Ford Ranchero Gas Tank
Many Econoline owners use a Mustang tank. The tanks are larger so longer straps have to be used. The intake needs to be moved from the center to the corner (radiator shop can do this). The Mustang sender works with the Econoline fuel gauge. I assume it should be similar with the Ranchero.
My son had a F250 with a fuel tank in the cab. He was having lots of rust problems. We could not find a new tank to go back in the cab, so we put a small piece of chain in it and rattled it around to b rake the rust loose. then we steam cleaned it, and bought some stuff called RedKote from ORiellys. It was like liquid plastic in a can. We poured it into the tank and rolled it around, then let it dry according to the instructions. It formed a plastic tank inside the old metal on and we never had a rust problem again. I hope this helps.
^ 1961/72 F100/750 In-Cab fuel tank reproduced by Blue Oval Truck Parts. ^
D0OZ-9002-C (replaced C4DZ-9002-F & G) .. Fuel Tank / Obsolete
1964/66 Falcon Ranchero/Station Wagon / 1966/69 Fairlane & 1968/69 Torino Ranchero / 1967/70 Falcon Station Wagon.
COLLECTORS AUTO SUPPLY in Oroville WA shows 2 = 800-414-4462 .. but may not have any.
At one time, dearbornclassics.com sold a reproduction.
96ford4x4turbodiesel
General Automotive Discussion
05-11-2004 10:49 AM
The Fife
03-19-2004 01:11 PM
OldRed49
04-21-2003 03:15 PM
