Where to connect trans temp gauge
There is a test port on the drivers side just above the pan. I have pic of it in my gallery
Ford Truck Enthusiasts User Gallery
Fixed, thanks!
thanks for letting me know, i fixed it, instead linked the picture, for some reason when you try to link pics in your gallery ie from an ipad, u can't right click the pic and paste just the pic url ,you can only copy the entire gallery url which is from an editing standpoint so no one else can see it.
Yes it is.
Yes it does, and quite well I will add.
Ands what would you do with the pressure reading there? How would you know if the reading is right or wrong? I wouldn't know by looking at a gauge, how do others know if it is right or wrong?
You can tell at idle and at stall, but at all other times the gauge will be ALL OVER the map. It will jump high, jump low, and just plain scare you. If you watched what the pressures are doing without having the calculated pressures request plotted alongside you'd think the trans was broken.
When I had fully instrumented transmissions in my development trucks at Ford I NEVER had a pressure gauge in the truck. It would have been useless for me to develop the transmission, I can't see any use for someone on the street.
geek guy
09-08-2012 06:03 PM
