1999 E450 Shuttle Bus
we have 1999 E450 shuttle bus has problem with turn signals and flashers flash dim cleaned ground still flash dim flasher seams to have low voltage to one wire only when wires are plugged on to flasher anyone have this problem before we are looking for wiring diagram anyone know where to find one any help would be helpful its a nightmare
Welcome to FTE, tractorsrlife.
When you say the "flasher" is dim, are you talking about the tun signal indicators in the dash display, or the actual turn signals on the front and rear of the vehicle?
Have you tried swapping the actual flasher unit? Here is a decent article on testing the flasher unit.
Testing and replacing a flasher unit | How a Car Works
69oiler
10-29-2017 08:11 AM
