SURVEY: IF YOU EVER PUMPED GASOLINE INTO A 6.4L PLEASE RESPOND. - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-10-2013, 03:03 PM
caddy's Avatar
caddy caddy is offline
caddy is starting off with a positive reputation.
Erased post
Old 11-10-2013, 08:41 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Quote:
Originally Posted by caddy View Post
Erased post
yEAH, MY BAD. I thought I caught it and erased it but I see I did not, sorry.
Old 11-10-2013, 10:28 PM
pbeering's Avatar
pbeering pbeering is offline
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by SPD&PWR View Post
So was this a company truck?
Yes.......and I own the company.....
Old 11-12-2013, 01:39 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
About 50,000 miles or so ago my wife put gas in the tank of my personal F-350. I drained the fuel, flushed the lines and that was it. Truck has been tuned with the 210 TP or higher tunes since about 10,000 miles where on the clock from new. Haven't had any issues with the fuel system since with over 100,000 on the clock.
I have two F-450 fleet trucks that have been exposed to gas in the tank, one is a 09, one is a 2010. I have a 3,000 gal on road diesel, 1000 gal off-road tank and a 500 gal gasoline tank in my equipment yard all clearly label don't see how the employees can make the mistake but at any rate one truck has about 20,000 miles since the issue and the other has about 80,000 since the issue, both have had no issues with the fuel systems since.
One of my close friends has a 2010 F-250 about 32,000 miles ago his girlfriend filled the truck with gas. We towed the truck to our shop and we drained the fuel, flushed the lines and changed the filters. He has been running the spartan 275 tunes since the truck was new and now has 75,000 miles total on the truck with no issues.
Old 12-12-2013, 09:44 PM
aggiect01 aggiect01 is offline
aggiect01 is starting off with a positive reputation.
My current f550 box truck had unleaded put in by the previous owner and they had to replace the entire motor at the tune of $16900 from Ford. They put unleaded in the new motor but caught it in time and had it towed and drained/filters changed for $800-900. I purchased the truck 1,000 miles after replacement and have had a few problems but may be unrelated.
Old 12-12-2013, 09:56 PM
StanleyZ's Avatar
Hey, thanks for the bump, I meant to do that every so often but it got away from me. What we don't have so far is anyone who cleaned up the gas and kept driving only to have a hard failure later. Not a big enough sample so far to draw and conclusions though.
Old 05-05-2014, 11:49 PM
fordfish's Avatar
fordfish fordfish is offline
fordfish is starting off with a positive reputation.
BP strikes again, add me to the list - I drove 70 miles on 50/50 before it died, I did everything like drop the tank , blow the lines, change the filters, but i dont hear my fuel pump when I hit the key??? checked a few fuses- still no pump sound??
Old 05-06-2014, 06:16 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Quote:
I take it there was no metal in the fuel bowl? Darn lucky.
Try the fuel cutoff switch on the passenger side of the dash. Open the door and on the side of the dash is the fuel door. See if it is tripped.
Old 05-06-2014, 10:06 AM
fordfish's Avatar
I did that, but no joy. Thanks.
Old 05-06-2014, 09:18 PM
ab257z ab257z is offline
ab257z is starting off with a positive reputation.
Another green handled BP pump. Put in some Diesel Kleen, and 3/4 tank of gas. 20 miles down the road engine started sputtering and I realized what I had done. Towed to a Ford dealership, purged tank, changed filters and no problems since. That was 30k ago. Oil analysis is reading a little high on iron though.
Old 05-06-2014, 09:19 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
Looks like you got lucky! For what it's worth, nothing that your fuel touches is oil lubricated. So the high iron has nothing to do with misfueling.
V10 Gas vs Diesel "The Truth" Budkole 1999 to 2016 Super Duty 374 07-11-2015 12:50 PM
Gasoline blew engine Brewmaster General Diesel Discussion 5 04-19-2014 12:08 AM
Big Propane Problem Please Help FordProTrucks Alternative Fuels, Hybrids & Mileage 9 01-12-2012 05:52 PM
6.4 diesel engine wiring f350idi 6.4L Power Stroke Diesel 3 04-30-2011 08:17 AM
Gasoline in Diesel Tank... tm0231009 1999 to 2016 Super Duty 21 01-16-2010 06:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
