NEED HELP FORD DOWN
NEED HELP FORD DOWN
First off, i own a 1993 f150 with a 300 i6. When i bought it it had bad gae in the back tank, i cleaned the tank then the fpr went out. While i wqs tyere i cleaned. tye throttle body and replaced yhe valve cover gasket. I then took it for a drive, she did great until i stopped at a gas station. It started running like crap. Missing, spit and sputterin then died. After that it would fire up then idle great but as soon as i gave it tjrottle it would die if yiu give it 1/2 throttle it will run but anymore or less it would run like crap and die. The fiek filter is good, cap, rotoer, wires ect are fine. The cat is good anf the check engine
ligt isnt on
ligt isnt on
JRMSVT03
08-20-2010 10:43 PM
grayson95f-150
09-11-2009 11:18 AM
