Poor gas mileage after tune up - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 11-06-2013, 11:57 AM
jmo1112 jmo1112 is offline
jmo1112 is starting off with a positive reputation.
Hey guys. I posted this in the E-van forum, but one of them recommended I post here, as well. So here's the issue:
I have a 2004 E350 V10 with 240k miles on it. I had a terrible miss, which became multiple cylinder misfires. I just replaced all 10 spark plugs with Motorcraft SP-479's, and all 10 COP's with cheapos from eBay (yes, I know the gamble there. Used them on my F150 and had great success, so I tried again with the van). Turns out 3 of the new cheapos were bad, so I put the original Motorcraft COP's back in those 3 spots. So no misses and no CEL now. However, my gas mileage is horrendous. Even worse than when I had all the misfires. Any ideas what could be going on?
Thanks for any help and/or ideas.
Old 11-06-2013, 01:08 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
I have never worked on a V10 on a van but the first thing I would do is check all the vacuum lines and the hose and fittings that come left valve cover to the air inlet tube not the PCV valve, the side may be different on a van. That tube is after the MAF sensor it can throw things off if it's sucking air.
Denny
Old 11-07-2013, 09:05 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I think your van has the same air box as the F-series. Check the rubber plug on the bottom of the MAF housing where the wires go through. If that's not in place, it'll allow a small amount of air to get past the MAF causing the engine to run lean.
I know, LEAN makes it use more gas? Yes - because of the lack of power, you need to lean into the gas pedal more, causing more air (and fuel) to enter the engine. But still lean, so lack of power, and yet, more gas overall.
Same theory applies to any other vacuum leak.
Old 01-07-2014, 01:14 AM
Hey, so this is a super late response, but I haven't really been driving much my van lately. I did use it this weekend, and after checking all the hoses and fittings, everything seems on tight, but bad gas mileage still remains. That said, I am smelling gas while the van is running. I've taken the dog house back off, as well as looked through the hood, and I can't SEE any gas, but I can certainly smell it. Any idea what I should be looking for, or what I should check first in trying to diagnose this?
Thanks.
Old 01-07-2014, 01:42 PM
truckfella's Avatar
truckfella truckfella is offline
truckfella has a good reputation on FTE.truckfella has a good reputation on FTE.
You say your mileage is horrendous. Can you be more specific on what it went from/to? Just curious.
Old 02-18-2014, 04:47 PM
Hi there. Unfortunately my lack of timely posting does not mean I've fixed the problem.
Under normal conditions, I was able to get between 350-390 miles to a full tank of gas. Mostly highway driving, but some city. In its current state, I get about 250 miles to a full tank of gas. Literally at least 100 miles difference. And it still smells like gas in the cab every time I crank the van.
Got any ideas?
Is it possible I don't have a spark plug seated correctly or something? I mean, it's not running poorly. No misses, and CEL. It's just eating gas like crazy, and smelling like gas.
Sorry again for my late response on this and bringing up old threads. My problems just haven't been solved yet, and it's been to freaking cold to go outside and try to fix things.
Old 02-19-2014, 12:09 AM
eberlestock's Avatar
eberlestock eberlestock is offline
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
I had the plugs changed on my F250 and noticed the same thing. The truck idles smoother but is using more gas. I am going to check the plug that somebody mentioned on the maf.
Old 02-19-2014, 03:21 AM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is offline
Bently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputation
Do you have any check engine light codes or pending codes? Have you changed the fuel filter? Check under the throttle body for vaccuum leaks as well.
I am a big fan on using OEM parts to tune up my truck and cars.
Old 02-19-2014, 03:03 PM
fordboy2's Avatar
fordboy2 fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.
I lknow I have read about cleaning the MAF, could this contribute to his issue if it is dirty?
Old 03-10-2014, 06:48 PM
Fordboy, I did try cleaning the MAF. It did not seem to help.
Bently, I don't have any CEL codes or anything. I, too, like to use OEM products. My budget, however, doesn't allow for such things. I also changed the fuel filter probably 30k miles or so ago.
Because of the rather strong gas smell, it was brought up to me that I must have a leak, as I shouldn't be able to smell gas with the engine running. I was told to check for a leaky fuel injector. I don't have a bad enough leak that anything is hitting the ground underneath the van, but when looking at the injectors, all of them are bone dry except number 1. It has a little pool of what I assume is gas inside the lip at the top of the injector. Could that be my issue?!
I do not have experience at replacing an injector. I've seen there a several videos on youtube and such on how to do it. However, I'm not sure what to expect when lifting the fuel rail. Is it difficult to get off? What steps do I need to do besides removing the bolts and disconnecting the fuel lines (the lines, of which I don't know the location)?
Thanks for your help and ideas on this so far and moving forward.
Old 03-11-2014, 11:17 AM
Okay I did a bunch of research last night, and I'm far less worried about removing the fuel rail than I was yesterday. Here's my next question.
If I have a leaking fuel injector, is it just the O-ring that is failing, or do I need to replace the entire injector? The van seems to be running fine. I don't have a miss. Clearly, that's a large price difference in parts, and I don't want to spend $100 for an injector when I could fix the problem by spending about $8 for O-rings.
Old 03-11-2014, 11:53 AM
ForKyleigh ForKyleigh is offline
ForKyleigh is starting off with a positive reputation.
Did you removed the fuel rail when you changed out the coils? If you didn't, I wouldn't expect that something went bad during the coil/plug change. There are four bolts, two on the sides of the intake manifold. There is also one on the back of the intake manifold. (should be the same as my f250) The one on the back of the manifold should be easy to access from the doghouse.
You should be able to inspect the O ring and determine if it is good or bad. Is it split, torn, etc?
Have you scanned the engine for codes? You should see if there are any "pending" codes. Pending codes will not make the CEL light go on.
You could try to just turn the key forward to the run position a few times to pressurize the system. Then sniff around. That way the engine is not running. You may need to re pressurize it a few times.
Otherwise the should be a valve on the passenger side of the fuel rail. Borrow/rent a fuel pressure gauge. Hook it up to the valve, and pressurize the system. It shouldn't fall. Yours probably will, but how fast? That will give you an idea of how bad it is.
Do you sniff the exhaust? Notice any difference? Did you plug your idle air control valve back in? It is just behind the throttle body.
Lots of ideas for you.... I am still a little new to the v10. But, no stranger to motors. I just pulled the top half of the v10 apart to find a coolant leak. I replaced all the same items you did while it was apart.
Old 03-11-2014, 04:27 PM
Those are lots of good ideas. I didn't remove the fuel rail when doing the coils/plugs, but it's possible that I put some undo pressure on the rail when reaching for bolts and plugs and such.
I haven't taken the rail out yet, so I haven't inspected the O-ring yet.
I don't have a diagnostics tool, but will the Autozone free check tell you pending codes? That is something I can certainly get done today.
I will certainly try a bunch of this stuff, hopefully today, and maybe get a little closer to a diagnosis.
Old 03-11-2014, 11:05 PM
I dont think the Autozone/ oreilly scanners will show pending codes. However the local dealership can do a diagnostic check for you. Of course there is a fee. I would call and check around the area. Unless you know someone with auto engenuity or a snap on scanner that is able to show live data.
Old 03-21-2014, 02:23 AM
This might be the slowest repair I've ever attempted...
So I was digging in to this today to try and repair this injector issue, and I think I may have found a bigger problem. Would these pics be an indication of a cracked fuel rail? It is definitely wet to the touch, and smells like gas, but I can't see gas coming out of there when I turn the key on. I can, however see it running down the injector.
None of the other injector spots look like this. Also, the connector that goes into the injector (not pictured) is totally discolored and basically black. None of the other connectors look like this.
If it is a cracked a fuel rail, is it just as straight forward as removing this one and replacing it with a new one? After a quick Google and Rock Auto search, I can't seem to find a fuel rail. Am I just calling it the wrong thing?
2003 Ex V10 Extremely Rough Idle BigBair Modular V10 (6.8l) 44 10-25-2016 10:08 PM
HELP! 2006 5.4L F-150 XLT has the shakes in OD Caseyw1 2004 - 2008 F150 17 08-03-2016 05:35 PM
COP REVIEWS - JUST THE FACTS MA'AM Hotairjunkie Modular V10 (6.8l) 28 06-19-2013 11:22 PM
Just changed plugs & COP's on F250 Utah F250 1997 - 2003 F150 3 02-13-2011 11:46 AM
same ol same ol- 4.6 misfire DanK5 1997 - 2003 F150 73 02-09-2011 05:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
