351M rocker arms - Ford Truck Enthusiasts Forums
351M rocker arms
Old 11-05-2013, 09:25 PM
jvilseckjr jvilseckjr is offline
jvilseckjr is starting off with a positive reputation.
351M rocker arms
Are the 351M and 351C rocker arms the same? I just installed a Comp Xtreame Energy XE274H-10 cam in my 79 351M. I was wondering if I could put 351C roller rockers on it?
Old 11-06-2013, 10:08 PM
dimora's Avatar
dimora dimora is offline
dimora is starting off with a positive reputation.
Quote:
Yes. You want 1.73 ratio.
Old 11-07-2013, 09:39 AM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
The rockers are the same, but check the fulcrums. The Clevelands had aluminum fulcrums, the late 351M's had iron fulcrums. The iron are what you want. They can also be sourced out of a 370/429 truck engine.
Old 11-10-2013, 01:02 PM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
the roller rockers will be the same and are all the same ratio. If you don't put in studs for adjustments you could have problems with geometry.
Old 11-10-2013, 06:39 PM
Rockers
Thanks for the info.. Will the 1.73 give more lift on the cam? adv dur is 274 286 with .562 .565 lift
Old 11-11-2013, 12:37 PM
No, that's the stock ratio for all the Cleveland/Modifieds
Old 11-12-2013, 12:35 PM
BuzzLOL BuzzLOL is offline
BuzzLOL is starting off with a positive reputation.
.. Yes, that cam already shows good lifts... that same cam in a SBChevy with stock 1.5 rocker arms would spec. out at much lower lifts...
.. As BearTracks hinted at, rocker fulcrum shims may be needed or changed to get proper hydraulic lifter preload...
.. If you're not satisfied with the performance of your 351M with that cam, it's prolly because the compression ratio is too low and that's difficult to fix with available off-the-shelf 351M pistons, hence why everyone converts 351M's to 400's...
351m to 400 build questions 79f1dy 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 02-21-2016 03:17 PM
Parts interchange oddfordjunkie 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 01-14-2013 12:43 AM
can a stock stamped rocker go bad? 78_f150 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 11-16-2011 07:41 PM
351M rocker arm oil diverters ??? Rob in Idaho 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-03-2011 10:52 PM
1977 351w rocker arm adjustment SEANSTER 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-04-2000 10:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
