Facet Duralift Fuel Pump
I've got one of these things, and I'm debating using it in place of my mechanical lift pump.
I don't like the idea of the mechanical lift pump failing and pumping fuel oil into the crank case, and having steady pressure and priming should be a good thing. I also like the cleanable 50 mircon filter screen and the inspection canister.
What does FTE think?
Does anyone else run these?
It's rated for 9.5-11.5 psi. What does the factory lift pump run, it's something like 3 or 4 right?
Check these threads they should have most of the info you need:
https://www.ford-trucks.com/forums/1...l#post10774080
https://www.ford-trucks.com/forums/8...ml#post8280861
Carrier Pump Group Buy
My truck is getting one If I ever get it back together again.
Mark
Mark
That concern seems to be spreading around here, like cavitation, only I'm sure you're more likely to cavitate then have the diaphragm fail like that.
Oh, it can happen, but it's not common.
Genlightening over on oilburners has a group buy of these for 80 shipped. Just got mine from him . Made bracket and picked up a relay and relay pigtail to wire mine in. Hope to do it tomorrow. Guys over on oilburners seem to agree the 11 psi will just make it like you have advanced it 1 deg. Standard motor makes a relay pigtail part s654 i think to use with the common 4 and 5 pin universal relays.
So is that something like the equivalent of turning up the injection pump allen key a flat?
It times the ignition event just like the distributor timing on a gas engine. Correct ignition timing is huge with these engines with respect to power output, fuel efficiency and ease of starting. You just need to be aware that changing your lift pump pressure will affect your timing, which may need adjustment/correction. Do a search on timing, there are many excellent threads here covering the topic.
