These 59ABs
These 59ABs
Getting ready to pull the engine out of this new/old beast and see what I find.
I have read and seen where the engines are attached to stands sideways and not out the back.
Is this because the bell housing is cast into the block, and people feel it's too much weight to hang out there?
I do have a means to adapt my stand, but just wondered is all.
Thanks for any input.
Here's one from Reds headers, pretty sure I've seem the less expensive as well.
Engine Stand Adapter [459] - $99.00 : Red's Headers, Speed Equipment For Old Fords
And some info on the HAMB:
http://www.jalopyjournal.com/forum/s...d.php?t=814178
Thanks Mike for the quick reply, I did find one source called Stumpys
Stumpy's Fabrication Works : Home
But it seems it limits access to half the engine that way?
Maybe I will pull it before committing to buy one. I have put a bell housing on a flat head six and hung it out the end with no issues. One even got away from me and spun around, but did not do damage.
Thanks again.
Thanks again.
These 59abs
I just ordered an adapter for a 59ab from Kurt Stumpf. Price was reasonable and his stuff comes with high marks from H.A.M.B. members. Also check out this home made adapter from Roseville Carl on the Flathead V8 forum:
Ford Flathead V8 .. 1932 thru 1953 • View topic - Custom Flathead tools
I just recently used the engine stand adapter from Stumpys(Kurt Stumpf) for my 59A motor and had absolutely no problems using. The only thing it will interfere with on the side of the motor is the exhaust ports, which for assembly and dis-assembly is not an issue. The only thing you will have to do to it is to did a couple of small holes in it for the locking pin so it doesn't spin on you. I don't believe he put them in because not all pins will be the same size, IMHO. Very nice chunk of metal fab (blots included)for $65. I have a pic of it being used in me thread.
Yeah I saw that thread, great work, really.
My shortcoming is metal work. I am a pretty good wrencher, electrician, plumber, and innovator of ideas, but I lack in the metal work.
I am getting close to retirement, so I may take a class if offered somewhere so I can putts around my shop.
And I can see Kurt does do good work.
timbersteel
02-16-2015 07:33 PM
