i have a 2003 f250 6.0 powerstroke with 226k and im fixing to pull my edge revolution out and do the SCT TUNER,ARP HEAD STUDS, BLACK DIAMOND 18mm GASKETS and replace 3 Injectors......IS THERE ANYHING ELSE I SHOULD DO BETTER OR AND GOOD SUGGESTIONS??????
NO black diamond head gaskets.You will do them again if you do,OEM only and good machining,and no whizzer wheels for cleaning the block and other surfaces
