89 f150 keeps throwing belts
Old 11-05-2013, 04:53 AM
keithaharkins's Avatar
keithaharkins
keithaharkins is offline
Last month, I decided to replace my belt because it was squeaking and getting cracked. Figured it was time since I haven't changed the belt since I bought the truck four years ago and had no idea when the last re out was changed. Since then, I've gone through three new belts AND the old one. My air pump pulley is wobbling ever so slightly, and I can't help but think that this is the issue. I've seen a few things about people bypassing this with a shorter belt, but nobody gives any information on what size belt to use. Anybody have any information on what I could do? I'm on a limited budget, and can't afford to keep replacing these belts after every 100 miles or so.
Old 11-05-2013, 06:30 AM
MT4x4guy's Avatar
MT4x4guy
MT4x4guy is offline
Pick yourself up a cheap roll of string and go around the pulley system with a bit of string, bypassing the air pump, this will give you a measurement that can be matched to a belt at the parts store. Make sure to follow the belt map that should be located under the hood and tell you the routing of the belt.
Old 11-05-2013, 07:33 AM
White Max's Avatar
White Max
White Max is offline
That depends on what engine and FEAD we're dealing with here. I've mentioned the routing and length for the 5.0L high-mount idler/low-mount tensioner FEAD many times on this site.
https://www.ford-trucks.com/forums/1...l#post11577213
https://www.ford-trucks.com/forums/1...l#post13240153
https://www.ford-trucks.com/forums/1...l#post10211643
Old 11-06-2013, 12:08 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Welcome aboard.
Yup...what engine?
Sometimes the tensioner can be wobbly and cause it to throw belts. Either the arm itself or the pulley.
I bypassed my 302 on my '89. The belt is 88" long(Autozone pt #880K6)
https://www.ford-trucks.com/forums/1...989-302-a.html
jspence105
01-28-2017 12:31 PM
Dennis Anderson
1999 to 2016 Super Duty
12-17-2014 04:46 PM
Dan Taylor
20
02-05-2008 09:59 PM
yomow
1978 - 1996 Big Bronco
01-09-2005 03:03 PM
yosemite98
02-11-2003 04:45 PM
Quick Reply: 89 f150 keeps throwing belts
