my winter list - Page 18 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
my winter list
  #256
Old 03-01-2014, 01:51 PM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
That's something else. I know my truck has had the right front fender and door worked on. Curious to see where and how long since..maybe run joshs to see I his left front shows up.
Travis, I'm going to try to round the cash up and pull the trigger as todd puts it.
Maybe someday if I ever get to get the other engine done with a bigger turbo then I will send them for a premium build which by then they will really need...sounds like a good plan?
  #257
Old 03-01-2014, 11:42 PM
fordman67's Avatar
I got some of this thermo tec heat wrap.It says it repels 90% of the radiant heat..and I swapped the 90* fitting at the pass rear hose so the hose is away from the up pipe wich is much hotter than the dp.
I removed the oe fuel hosses and fittings. Im glad I am replacing them for additional reasons because the outer shielding was cracking so it was just a matter of time. heres the swapped front fittings on both sides. also I found my ebp tube and fitting were completly clogged up si I cleaned them also.
  #258
Old 03-01-2014, 11:59 PM
fordman67's Avatar
I FINALLY have all of the plumbing on the engine completly done. I remade the drivers hose 3 times before I was happy with it. I was able to run it up between the turbo pedestal and plenum and swap the 90* hose end for a 45* going into the 1/8 npt to -6 90* fitting in the drivers head...IF that makes any sence.
I put the compression to pipe to pushlock fittings on and its all sealed up. I am pretty happy with it all..but we will see how long that lasts.
I was struggling with how I was going to go from the 5/16 hose from the switcher valve and get to the 3/8 push-loc. I had planned just to do a barb to barb connection but I could not talk myself into that.
I came up with a reducer in the filter head 1/2" pipe to 1/4" npt with a ball valve and a barb. Now the oe hose will just come off the hard line and clamp on the barb. I have seen some systems with a valve to shut fuel off when changing filters. I dont think its probably a big deal but I will try it out.
special note..^^^^ thats my vise btw...its a very good vise..we ALL need a vise..
  #259
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
Aaron, I am wondering about the EBPV tube. I am 99% sure mine has been gutted so does that mean the tube still needs to be cleaned? I was looking under there this morning when lookin for boost leaks and saw that it was really dirty. Dangit that Efuel setup makes me jealous!
  #260
Old 03-02-2014, 12:09 AM
fordman67's Avatar
Tomorrow I plan on welding the pump/filter bracket on and finishing the last two connections. the factory hard line will get a compression to pipe to pushloc on it and the rubber hose goes on the barb.
next will come wiring. I tore down the fuel bowl harness apart. WHAT JUNK it is. its harder than wood pecker lips. I will be rewiring that mess and doing away with the oe connector on the pass side.
fuel pump wiring needs built. I have the switch that bill and others use and plenty of relays.
  #261
Old 03-02-2014, 12:18 AM
fordman67's Avatar
I think the pcm uses it for other functions also. AND with that fancy new monitor you should be able to see turbo drive pressure by the sensor I think byron.
  #262
Old 03-02-2014, 12:23 AM
Quote:
Hmm, I'll have to check it tomorrow and see. It doesn't seem like one of the parameters I have seen, but I could be wrong. What did you have to do to get to that tube? Am I looking at removing the turbo and all the pedestal? Man I hope not.
  #263
Old 03-02-2014, 12:33 AM
fordman67's Avatar
pass acc bracket.its behind it. easy to work on. the sensor is behind the hpop resivour. and the tube goes to the pass manifold at the front
  #264
Old 03-02-2014, 01:03 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
You got it looin good buddy!
  #265
Old 03-02-2014, 07:47 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
That looks really good A-Aron. I like it a lot. Where did you get the thermo-wrap?
  #266
Old 03-02-2014, 08:07 AM
fordman67's Avatar
It came from summit. i got a 4" boot for my intake pipe..i have a plan to change it to get rid of the stock rubber piece between the breather housing and air filter metal 45* part.
  #267
Old 03-02-2014, 09:09 AM
madMatador78's Avatar
madMatador78 madMatador78 is offline
madMatador78 is gaining momentum as a positive member of FTE.
Wow Aaron! This all looks amazing! Good work! Feels good doesn't it.
  #268
Old 03-02-2014, 09:37 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Motivation has arrived, parts are flying on!!
  #269
Old 03-02-2014, 01:21 PM
joshjen2000's Avatar
joshjen2000 joshjen2000 is offline
joshjen2000 is starting off with a positive reputation.
Your getting a ton of progress with out me screwing up the situation! I hated not getting to come over yesterday to work with you, but the husband duty card fell on me hard! be careful with all the ice out there today!
  #270
Old 03-02-2014, 11:22 PM
fordman67's Avatar
Well, the bracket is welded to the frame and filters and pump are installed and plumbed. I got the oil pressure switch installed and need to get started on the wiring. I had to stop and do some cleaning on the shop. I really need to get the onan generator off my work bench so I pu t the oil pan and pickup back in. IF I dont work tomorrow because of the weather I may try to get it on the cart and the front axle torn down for the axle seals.
heres some truck ****.
Installed SX257 Turbo from R&D- replaced 093 with wicked wheel Shawn MacAnanny Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 06-25-2016 03:07 PM
Intercooler Install OBS Ford (Pic heavy) Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-09-2014 10:43 AM
Trucks in the shop for winter work 427 fordman 1994.5 - 1997 7.3L Power Stroke Diesel 870 04-01-2013 08:16 PM
Painting turbo, spider and IC pipes 99StrokeXLT 1999 - 2003 7.3L Power Stroke Diesel 7 03-12-2011 07:50 AM
My first month as a Powerstroke owner....Lots of pics viking89 1999 - 2003 7.3L Power Stroke Diesel 28 06-23-2010 05:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
