I have a have a Dana 60 in my f250 I want to swap it with a draw Dana 70 rear axle from a 1980 s ford cube van I noticed the spring perches and shocks were mounted 2 inches wider than my Dana 60 will this work?
Well, measure the overall drum to drum width..........then decide whether you want to remove old spring perches and move them to accommodate the different width of your springs. Then if it will work how about rear axle ratio compared to the Dana 44 front axle youve already got( or Dana 60 front if your lucky)
It is maybe an hour job for a welder to move spring perches with the rear end out of the truck.
Be sure to take pinion angle into account when locating them.
Well I managed to find a Dana 60 just like the one I have the bearings seem to be fine in this one. I don't know what gearing ratio I have now tho I looked on the tag but its to rusted away to tell. I don't understand the numbers on the ring either can anyone help me here?
