12 volt solenoid
Old 11-19-2013, 09:31 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
Originally Posted by ALBUQ F-1
I stand corrected (again)! It is like below?
It can't be exactly like that. Power for the I lug has to come from somewhere. Power goes in through the S lug, so it either goes from there to the I lug, or it comes from the Starter side as originally drawn.
Old 11-19-2013, 10:51 PM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
I used a Standard Ignition SS-587, it's an insulated base with one terminal. It works just like the stock 6v one that Ross pictured, works off of the stock push button grounding on the dash.
Old 11-20-2013, 10:04 AM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Yes! Thank you for the drawing, I was going to look for a used solenoid and take it apart for a photo but your diagram works just as well. As you can see in your diagram contact with the "I" terminal is only made when the solenoid is engaged and it does not matter which side the battery and starter cables are connected. I will start a new post on why it is always a good idea to use the "I" terminal even on electronic ignitions.
Old 11-20-2013, 10:15 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The horizontal black bar in the drawing is a big copper washer that shorts across the two big terminals and the I terminal when energized. (Note the bar is where they cheapass on cheap solenoids).
Old 11-20-2013, 11:51 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
I got it now, and it makes perfect sense. Last night, (tired and without glasses) I didn't see the drawing the same, just a broken circuit. Sorry for the confusion and thanks for the clarification. It is just how I pictured it in my mind, but the ol' eyeballs didn't make the connection.
tjdad62
02-02-2015 12:20 AM
LARIAT 85
09-16-2011 09:22 PM
wyazel1
47
04-03-2008 03:37 PM
891/2ton
09-05-2006 07:51 PM
jczab
1978 - 1996 Big Bronco
08-15-2001 08:58 PM
Quick Reply: 12 volt solenoid
