Best way to shim 51 f1 cab leaning back - Ford Truck Enthusiasts Forums
Old 11-03-2013, 09:51 PM
robmiller67 robmiller67 is offline
robmiller67 is starting off with a positive reputation.
I am restoring a 51 f1 and need some advice on how I should go about making the cab of my truck to sit more even, it is leaning quite a bit toward the back of the cab. The gap between the cab and bed is roughly 1/2 inch at top and 2 inches at bottem. I loosened the bolts of the brackets that hold the cab to the frame, then jacked the cab up off the frame in the back to try and make more level. I got about 1/2 inch gap now between cab and frame and stuck some washers there until I put some type of permanent spacer there. Is this ok to do and what should I use for spacers thanks, Rob.
Old 11-03-2013, 10:35 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
You really should either buy new cab arms or rebuild the originals.
Old 11-04-2013, 08:09 AM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
I think we need to see some pictures. The rear of the cab should be suspended on a pair of arms, there is nowhere to put washers or shims. It sounds like your cab may have been modified.
Old 11-04-2013, 08:24 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
I looked at your album . Nice truck . You need a service manual and a cab Bushing Kit . Available from one of several vendors listed at the top of the page .
Old 11-04-2013, 08:36 AM
bobbytnm's Avatar
bobbytnm bobbytnm is online now
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
The rear cab mounts are probably worn out. New mounts are available, or if you are a cheapskate like me you can rebuild them for not too much money.
Here is a link to a thread on it;
http://www.ford-trucks.com/forums/12...t-rebuild.html
Bobby
Old 11-04-2013, 12:16 PM
My cab is sitting on the frame so I am going to replace the rear arms with new ones. How much will this raise the cab off the frame, and is there any other pads, rubber, ect. that I need to purchase, thanks.
1952 F3 Front Brake Drum & Backing Plate Spacer Dexter 1950 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 09-28-2015 01:20 PM
Bed Bolt Holes - 4x4 Frame Swap red450ih 1967 - 1972 F-100 & Larger F-Series Trucks 9 03-08-2015 05:33 PM
Anti Cab Skirts phot request my1954fordf100 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-29-2015 07:10 PM
Question on stepside bed mounts swampthang 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-29-2014 10:47 AM
rear cab to frame measurement needed drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-03-2014 11:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
