87 f-150 302 backfiring overfueling etc…. - Ford Truck Enthusiasts Forums
Old 11-03-2013, 08:14 AM
shanes66charger shanes66charger is offline
shanes66charger is starting off with a positive reputation.
So my little brothers 87 f-150 had never had any trouble. He was driving back home one sunday and it suddenly began sputtering/cutting out etc……intermittently…He soon realized that if he drove literally 85 mph and above it was fine. It would only act up if he slowed to pass etc.
On arriving home, at idle there was literally raw liquid gas leaking out of several of the manifold ports at the head…..also out the exhaust pipe. I do believe ALL cylinders were heavily over fueling, but only leaking at head on a few due to leaky gaskets.
After some reading, He decided the temp sensor may have failed making the brain believe it was really cold out maybe? So after he put the temp sensor in, he's never seen raw gas flooding out, but it smells excessively rich and randomly backfires which it never backfired before he put the temp sensor in!
Every component has been either tested or replaced, coil, cap and rotor, dist mounted IGN module, IAC etc. We pulled the computer and looked for VISIBLE problems (burned diodes etc) and found nothing…..
My theory now is that maybe the temp sensor failed, sending it into a severe over fueling condition…..during that time the 02 sensor became plugged and or ruined. Thats the only component he HASNT replaced or pulled out. Im leaning this way because the symptoms clearly changed when the temp sensor was replaced.
He has a 460 hes wanting to drop in it, and is at his wits end with this thing LOL
Any advice, thoughts, experiences are appreciated.
Hes gonna get another new temp sensor and an 02 sensor today and if that don't fix it, he's probably gonna be looking for a lighter…...
Old 11-03-2013, 08:17 AM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Did you guys check out the fuel pressure reg vac line? Any signs fuel has been in it?
What is the fuel pressure reading?
Old 11-03-2013, 08:18 AM
I know he checked the fuel pressure….ill have to ask him what it was….
also it starts great, always has….the exhaust is rich enough where it'll burn your eyes in the shop in a minute
THE CREAM PUFF PROJECT...... paintubturner 1994.5 - 1997 7.3L Power Stroke Diesel 74 02-27-2017 11:41 AM
Christmas Epistle 2016 jniolon 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 12-17-2016 07:20 PM
Efuel fail... selector valve fail...selector switch maybe failed..WTF nossliw 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-15-2016 03:08 PM
Helipirate’s 1978 Ford F250 Super Cab 4X4 Project with Lots of Pictures helipirate 1973 - 1979 F-100 & Larger F-Series Trucks 237 08-14-2015 09:44 PM
Getting a free F350… this should be fun. krooser 1987 - 1996 F150 & Larger F-Series Trucks 43 07-28-2014 09:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
