Replace Oil Pump???
Replace Oil Pump???
Hello all, I'm in the process of changing a leaking oil pan gasket.
After much wailing and knashing of teeth I finally got it out.
Now that I have the oil pump and pickup out, I'm wondering if I should replace the oil pump.
The truck is a '95 F250 regualar cab 2WD with a little over 200K miles.
However the engine still runs strong (351W 0 - 60 in about 9 seconds which ain't bad
for an 8500 lb white brick)
I know from past experience with 302's the oil pumps tend to give out around the same milage.
Any thoughts on the matter would be greatly appreciated
Thanks
Guy
Thanks
Guy
Change pump while you have pan off and old pump and pickup out. Buy new oil pump hex shaft...when you get new shaft, check the locking clip distance on new one and IF its closer to the top than the old one BE sure to set it same distance as old one cuz if you dont, the dizzy will stick up a 1/4 inch higher and really pi** you off!!! Only need to install standard volume oil pump.
drunkenrich
11-16-2009 09:01 PM
