1970 360 to 300 six SWAP - Ford Truck Enthusiasts Forums
Old 11-02-2013, 01:46 PM
missfordgirl94's Avatar
missfordgirl94 missfordgirl94 is offline
missfordgirl94 is starting off with a positive reputation.
hey guys. I have a 1970 ford f100 that originally had a 360 in it. I rebuilt an '84 300, and dropped it into the truck.
engine to tranny is good, but having issues with the original radiator. this new motor is quite a bit longer, and can't fit radiator and clutch fan. is there a way to get around this? thanks! will post pictures later.
Old 11-02-2013, 01:52 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
I may be wrong , have been in the past , but... I do think there are different mounting positions . Behind the rad support or in front of the rad support .
Old 11-02-2013, 01:56 PM
JWC 3's Avatar
Sorry , more to the post . How bout no clutch , straight fan ? Better yet ( to some ) go electric on the fan set up . Saves a bunch of room ,with a pusher set up . Also gain a few horses . Just a thought !
Old 11-02-2013, 02:15 PM
Quote:
what electric fan have you seen? all the ones I've looked at dont push enough cfm. that's the route I would rather go if I can find the right one
Old 11-02-2013, 02:16 PM
and I will post pics of my setup and check out that mount up you were talking about soon.
Old 11-02-2013, 05:47 PM
2FordTrucks 2FordTrucks is offline
2FordTrucks is starting off with a positive reputation.
I had this same issue. Without the clutch your fan will sit just under a inch away from the 3 row radiator if that is what you have. I learned the hard way what bad motor mounts and a fan that close does to a radiator and fan.
Old 11-02-2013, 07:51 PM
Quote:
oh damn. I thought about just running it but I have to weld in the mounts cause they sit too at forward for bolts, so that's a no go. did you ever redo it and make it work?
Old 11-03-2013, 08:51 AM
I installed the proper radiator so they're are no more issues. My truck dose not need the big super cooling guy in it. This truck is just meant to use as a toy. I was told once to get a pusher elec fan and upgrade the alternator but this should work fine.
1970 heater problems abe 1967 - 1972 F-100 & Larger F-Series Trucks 7 02-17-2016 03:02 PM
Thermostat for 70 360 abe 1967 - 1972 F-100 & Larger F-Series Trucks 17 12-17-2014 09:32 AM
Radiator cap for 360 abe 1967 - 1972 F-100 & Larger F-Series Trucks 3 12-13-2014 05:42 PM
stuck on a 360 to 300 swap missfordgirl94 1967 - 1972 F-100 & Larger F-Series Trucks 6 11-16-2013 11:00 PM
360-300-360 bigolford Engine Swaps 2 08-28-2004 05:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
