1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Headlight Bulb Replacement
Old 11-02-2013, 01:32 PM
Ford Big Rig's Avatar
Ford Big Rig
Ford Big Rig is offline
I upgraded my headlight bulbs today to Sylvania H13. I used this as a guide:
Remove F250 Grill
I tried it this way first, and I could not remove the coolant tank so I suggest don't take it off, remove the grill much easier:
"On my 2011 F250, I replaced the headlight bulbs without removing the grill, the right side was pretty easy to get to, the left side was a bit trickier but I easily removed the air box/coolant reservoir out of the way and I was able to get my hand down there and replace the bulb. I had the whole job done in ten minutes."
Old 11-02-2013, 02:55 PM
seville009's Avatar
seville009
seville009 is offline
The problem I had when I had to replace a blown bulb was that I didn't have a long extension to get at the bolt at the bottom of the headlight assembly. Luckily I could move the light enough to get my hand back in behind it yo get the bulb out
Old 03-13-2014, 02:05 PM
Japar61's Avatar
Japar61
Japar61 is offline
change bulb
I have a new 2014 f250 that I just upgraded the headlight bulbs on. I found it was quick and easy to just remove the 5 small bolts that hold the wheel well cover on and pull it back on the driver side. You can just reach in and change the bulb from the back and put the well cover back on. It took me less than 10 min to do the driver side. The other side you can just reach in from the top and change it. Hope this helps!
Old 03-14-2014, 10:18 AM
bryyce62's Avatar
bryyce62
bryyce62 is offline
It just takes a miunte or two to get the grill off...After you've done it once.
AKHunter93
11-21-2015 11:35 PM
skscci
04-07-2012 04:55 PM
Whit350
10-31-2009 01:28 PM
timmyjimmy5150
1997 - 2003 F150
02-18-2009 06:19 AM
mifree
1997-2006 Expedition & Navigator
02-25-2004 02:59 PM
Quick Reply: Headlight Bulb Replacement
