making bad sounds
Old 11-01-2013, 08:54 PM
Bigal700's Avatar
Bigal700
Bigal700 is offline
making bad sounds
Hi i got a 1997 ford f250 with 7.3 turbo and it all the sudden started starting hard so i thought bad glow plug had a few bad ones so i replaced them all and it still starts hard and smokes and when its cold it make a thumping sound and dont have power until its warm or at a higher rpms at low rpms it makes the sound what could this be?
Old 11-01-2013, 10:18 PM
fordpride's Avatar
fordpride
fordpride is offline
Is it a sucking/blowing sound ?
Old 11-02-2013, 01:44 AM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Is the glow plug relay working? Mine would click but it still wasn't working. I replaced it and all is well.
Old 11-02-2013, 01:53 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
Injector Orings perhaps?
Old 11-02-2013, 02:21 AM
richdawg's Avatar
richdawg
richdawg is offline
Could it be the EBPV? Maybe not with the thumping sound though.
Old 11-02-2013, 08:33 AM
Bigal700's Avatar
Bigal700
Bigal700 is offline
In my opinion i think its a injector just the way it acts and i haven't checked relay my biggest thing is why the sound is there
Old 11-02-2013, 09:44 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
If your glow plug system isn't working like it should be these things will really hammer and knock until they get a little heat in the engine. I;m guessing that's what you're hearing.
Old 11-03-2013, 09:19 AM
Bigal700's Avatar
Bigal700
Bigal700 is offline
I tested my relay and its working fine. I ran a test with my scanner and it said an exhaust valve
Old 11-03-2013, 01:25 PM
Bonanza35's Avatar
Bonanza35
Exhaust valve or EBPV? Never heard of a scanner that said exhaust valve is bad.
Old 11-03-2013, 03:52 PM
Bigal700's Avatar
Bigal700
Bigal700 is offline
Wats a EBPV????
Old 11-03-2013, 06:45 PM
DIYMechanic
EBPV is Exhaust Back Pressure Valve. It's a butterfly valve on the outlet side of the turbo that is intended to close partially to aid in cold engine warmup. The engine can run just fine without it and a lot of people unhook it. The sensor for it tends to fail and then it closes when it shouldn't and impedes engine performance.
Old 11-03-2013, 09:48 PM
Bigal700's Avatar
Bigal700
Bigal700 is offline
I bet u that's wat it is i had an exhaust leak that i got fixed ill dig into it thank you
Old 11-04-2013, 06:42 AM
DIYMechanic
There is a two wire connector under the intake side of the turbo. If you unhook that it should disable the system.
Old 11-04-2013, 07:01 AM
Bigal700's Avatar
Bigal700
Bigal700 is offline
Ok ill do that
mx4nam
29
01-29-2015 07:59 AM
5wests
10-04-2012 01:12 PM
SUPERDUTY OUTLAW
12-20-2009 04:24 PM
outdoormaniac
11-30-2009 11:56 PM
CheaperJeeper
09-23-2006 11:24 AM
Quick Reply: making bad sounds
