1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Looking at 06 F350 5.4 Question
Old 11-01-2013, 04:58 PM
PeteB4's Avatar
PeteB4
PeteB4 is offline
Is there any way to tell if the seller has "reset" any check engine light?
My buddy told on Dodges you can cycle the key a few times and get a "blinking light" code. Can something similar be done on an 06 F350 5.4?
Old 11-01-2013, 05:08 PM
02TB250's Avatar
02TB250
02TB250 is offline
Not as far as I know but any serious issues should resurface within a short test drive if the code had been cleared. However make sure the check engine light shows up when you turn the key to make sure they haven't removed the bulb or its burned out
Old 11-01-2013, 05:11 PM
PeteB4's Avatar
PeteB4
PeteB4 is offline
Ok, thank you! That's what I thought. I'd never heard of it and couldn't find anything in a search...other than some earlier models.
TM41
05-18-2011 11:35 AM
Rotterdam24
12-06-2007 06:48 AM
Quick Reply: Looking at 06 F350 5.4 Question
