acceleration hesitation
hello i have a 1990 f150 with a 4.9 and i have a real bad acceleration problem it bucks and sputters till 2000 rpms then smoothes out untill under 200 rpms and has to warm up for about 10 minutes to run right heres my specs;
idle : @925 rpms
battery voltage at idle :13.96 ( high output alternator)
fuel pressure : 22 psi at idle
oil pressure :42 psi @ 2000 rpms
coolant temp warmed up : 210 degrees farenheit
compression test: (psi)
1(125 2(122 3(122 4(121 5(130 6(125
no vaccum leaks ,new tps sensor ,new cap, rotor ,plugs and wires and coil and icm and fuel filter its got over sized valves all comp cams valve train and a ported head .also a cold air intake .
idle : @925 rpms
Removing the vac line to it should increase the pressure 5 to 10 psi, if you get no increase at all that'd strongly suggest the FPR as the problem.
Still might be even if you see a rise in pressure vac line removed (engine running of course)
Check for signs of fuel in the vac line too.
Suggested quick test for low pressure, pinch off rubber section of return line (not completely but enough to greatly restrict flow back to tank). If pump is up to spec pressure should rise to or even beyond spec, if so replace FPR.
If restricting return line flow to tank does not increase fuel pressure reading, the pump would be suspect instead.
Think of it like putting your thumb over end of garden hose to increase distance you can spray it, while no more water is coming to the end of the hose by limiting what can exit it you increase the pressure.
Slash19
35
06-09-2020 09:48 PM
klhwarf
03-03-2001 01:33 PM
