Rear Axle Ratio and Transmission - Ford Truck Enthusiasts Forums
Old 11-01-2013, 05:58 PM
richardbrust richardbrust is offline
richardbrust is starting off with a positive reputation.
I have a 1960 F250 with a 4-speed - engine is 292 if that matters. Never use 1st, start in 2nd, and am in 4th in no time. Seems like 40mph is pushing to the limits of this beast.
So I did some research on rear axle ratios, and I believe I understand that concept. What I don't understand is if I change the rear end, and drop it down to a 3.73 or something similar, what effect, or limitation, will the current transmission have? (don't know the details of the current tranny).
Is there some info/sites on the relationship between the two. I seem to have found the rear end info easily enough, just not both together. Thanks!
additional info:
  1. currently having new front end put on, will change from 8 lug to 5. I say this because I'd like to have them all 5 lug now anyway, so rear end change is on the "to-do" list.
  2. Have been told Ford 8.8 5x4.5 bolt pattern is the way to go, will add disc brakes as well.
Old 11-01-2013, 06:16 PM
Maltman's Avatar
Maltman Maltman is offline
Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.Maltman has a very good reputation on FTE.
do you have a tach to see what RPM's you are turning at that speed?
Old 11-01-2013, 06:58 PM
no, I'm guessing on speed even. Fuel gauge works, that's about it
Old 11-01-2013, 07:02 PM
Maltman's Avatar
haha, right on man! Have you tried to see what gear ratio you have now? you tube has videos...
Old 11-01-2013, 07:31 PM
Current ratio is 4:11. Thanks much...
Old 11-02-2013, 07:55 PM
deyomatic deyomatic is offline
deyomatic is starting off with a positive reputation.
Get a tach and see what you're spinning. I'm guessing the tranny is manual. The only issue I ever had with swapping gears to higher ones (I went from 3.89 to 2.90) was that I had to slip the clutch more to get the car moving. Maybe that was just too high for the weight of the car. Not sure. Play around with the gearing calculators online. Richmond gears has a good one, 4.11 to 3.73 may not be a big enough difference for you.
Old 11-05-2013, 01:48 PM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
1960 F250. You might have the 4.56 gears. What is your axle code on the rating plate? No matter whar rear gears, and F100 or F250, the 4 speed transmission was the same (Warner T98A). Changing axle ratio will have no effect on transmission. What ratio to use depends on how you will use the truck. You have a low enough first gear to get an empty truck rolling with any sane axle ratio.
Old 11-06-2013, 01:16 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Which front end are you using? That will make a difference as to bolt pattern. Standard Ford F 100 is a 5X5.5 until, IIRC, '96. Cars of the same period were 5X4.5. I think it changed to metric in '96 for both cars and trucks.
Looking For Rear Disk Brake Options (56" Ford F100, Dana 60 Rear End) apkarian100 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-09-2015 01:21 PM
1/2 ton Dana 60 reliancef150 1967 - 1972 F-100 & Larger F-Series Trucks 26 12-30-2014 05:08 PM
1956 F250 axle question bmann52 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-22-2014 11:55 AM
help finding rear diff gears please luthoro 1987 - 1996 F150 & Larger F-Series Trucks 10 01-19-2014 01:49 PM
1964 rear end gear question SocialDistortionFan 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-19-2013 07:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
