60 Ford Steering box Question
Old 07-30-2013, 06:04 PM
Fshmn62's Avatar
Fshmn62
Fshmn62 is offline
Can anyone tell me how to get steering box off column without damaging either one. Would like to sell box after separating it. Will be keeping old column for project. thanks for any info.
Old 07-30-2013, 07:09 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I've seen them come out of the shaft from the bottom after you remove steering wheel.
Old 07-31-2013, 08:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Steering shaft and worm (3524) is a one piece assembly, goes directly into the gearbox.
Old 07-31-2013, 10:21 AM
Fshmn62's Avatar
Fshmn62
Fshmn62 is offline
60 Ford steering box question
Thank you NumberDummy
Old 07-31-2013, 04:23 PM
Damifiknow's Avatar
Damifiknow
Same set up for column shift?
Old 07-31-2013, 04:54 PM
NumberDummy
Look at the parts catalog pic in post 3.
1965 F100/250 2WD's: First Ford trucks to have a steering coupler (rag joint) between the steering shaft and the input shaft of the steering gearbox.
Old 07-31-2013, 05:17 PM
Damifiknow's Avatar
Damifiknow
Sorry I didn't see and thing related to column shift linkage in picture.
Old 07-31-2013, 05:56 PM
NumberDummy
Sorry I didn't see anything related to column shift linkage in picture.
Column shift linkage has nothing to do with the original question. OP wanted to know how to separate the steering gearbox from the column.
Since the steering shaft goes directly into the gearbox, the whole enchilada must be removed from the truck as a one piece assembly.
Doesn't matter what type of trans it has, same jazz applies to all M/T's & A/T's.
Old 11-06-2013, 09:15 AM
richardbrust's Avatar
richardbrust
richardbrust is offline
I know this post is 3+ months old, but I just came across this same situation this week - bought a column, but new front end will be power steering.
I guess my question for you is "what did you do to connect the old column to the power steering after removing the box"?
I have the box somewhat apart, the wheel off, but have not removed the shaft/worm yet, as I was not sure what stays and what goes off this older unit. Any advice is most welcome
Thx...
Old 11-06-2013, 12:09 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Thx...
You'll have to get a u joint of some sort. Cut the worm off and put the u joint in it's place. CPP, No Limit, etc. will have what you need. You'll also need to get a piece to go between the u joint and the front end. And then prolly another u joint. I'm not sure, but I think you'll also need something to hold the column in place.
throttleshift
1947 and Older Ford Trucks
05-19-2014 07:17 PM
FunknFord
15
05-12-2014 08:28 AM
tbird4
05-31-2006 07:48 AM
Christopher2
05-23-2005 01:57 PM
katdon2001
03-03-2004 11:17 PM
Quick Reply: 60 Ford Steering box Question
