Anyone ever replace REAR Axle shaft 9.75 ? ABS Ring question - Ford Truck Enthusiasts Forums
Old 11-01-2013, 04:19 PM
royb royb is offline
royb is starting off with a positive reputation.
the factory rear axle shaft ABS ring is all metal
the FORD replacement rear axle shaft with ABS ring has plastic around the teeth. Is the plastic supposed to be removed ?
2010 F150 FX4
okay i got it figured out - the ABS system uses magnetic sensors that read the metal ring with teeth . this type of system can read the teeth through the plastic so it doesn't need to be removed. the plastic is there to reduce dirt build up in the teeth .
Old 11-01-2013, 08:14 PM
never mind - i got it figured out.
the plastic stays the speed sensor is magnetic and reads the teeth through the plastic . the plastic is there to keep the dirt out of the teeth.
Old 11-01-2013, 08:17 PM
by the way the CPU converts the magnetic reading from the speed sensor into volts then makes the adjustments to the various systems .
Speedometer Question WolfHunter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-04-2017 02:41 PM
Rear End info from 73 Dents to 96 f150s axelgawn Georgia Chapter 1 03-05-2016 06:20 AM
ABS Lessons Learned (valuable insights) beamundson 1997 - 2003 F150 2 03-28-2012 04:23 PM
Flywheel ring gear replacement 59INA40 1961 - 1966 F-100 & Larger F-Series Trucks 8 08-04-2010 06:09 PM
bad driveshaft? autx790 1978 - 1996 Big Bronco 7 02-11-2008 06:43 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
