51/52 hood length/ new 52 f6
Old 11-01-2013, 02:16 PM
Chris 56 f6's Avatar
Chris 56 f6
Chris 56 f6 is offline
Ford 51/52
Are the fenders and hood longer on a f6,f7,f8 then a f1
I m looking into this truck but the hood looks funny!?
Old 11-01-2013, 03:29 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is online now
Correct me if im wrong but i thought i read that the f7 and f8 had longer hoods than the f6 and smaller.
Old 11-01-2013, 03:35 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
AFAIK, the hoods are all the same exact part on all F series, 1-8. The fenders are the same dimensions on the F2-6 as they are on the F1, just the wheel opening is larger. F7-8 fenders are wider than the smaller series, and it's possible they could be slightly longer, too, but I'm not aware of any differences in length from the others.
The hood in the above pic looks funny because it's not attached to the hinges and is sitting askew on the fenders. It's forward and to the right of it's normal seated and closed/latched position.
Old 11-01-2013, 03:36 PM
reg1952's Avatar
reg1952
reg1952 is offline
Looks like the right hood. Paint colour and rust are the same. Looks like its not bolted on and is sitting more to the right and maybe not back all the way.
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Hoods should all be the same....the hood in that pic is just sitting on the fenders. Not attached. I think it's just an optical illusion....
edit Dang you guys are quick!!!!!!!!
Old 11-01-2013, 04:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Makes me wonder if the engine has been pulled?
Old 11-01-2013, 04:45 PM
Chris 56 f6
Would my 272 out of my f6 fit in this truck?
Old 11-01-2013, 04:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No, Y-blocks don't have the same bellhousing pattern as flatheads, as far as I know.
Note that this truck had (has?) a 6-cyl engine (215), so a later 223 should bolt up.
Old 11-01-2013, 07:10 PM
Chris 56 f6
Vin F6M2SP13122
I need to find my decoder ring? Where did my wife put it ??!
Old 11-01-2013, 07:36 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Originally Posted by Chris 56 f6
Vin F6M2SP13122
F6 - 2 ton conventional cab
M - 254 cu in 6 cyl
2 - 1952
SP - Twin Cities (St. Paul) plant
13122 - production number (looks to be late)
Get the sequence stamped into the cowl (should be center and toward the top) and we could tell you the build date and color.
Old 11-01-2013, 07:41 PM
Chris 56 f6
M - 254 cu in 6 cyl
2 - 1952
Thank you panel man!
The guy did not want to budge on that f8 I was trying to get. It had no title and did not run and he wanted 2 bills for it?
Old 11-01-2013, 08:09 PM
Chris 56 f6
Will my 272 bolt up to that bell house from a 254?
Old 11-01-2013, 09:07 PM
51dueller's Avatar
51dueller
51dueller is offline
The F-7/8 and F-5/6 with 176/194" wheelbase fenders are wider, longer and taller.
There is a little filler piece to fill the gap as they use the same inner fenders.
Even the magic air tube has a little extension as well.
Old 11-01-2013, 09:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Nope
Is there an engine in the truck?
Old 11-01-2013, 09:31 PM
51PanelMan's Avatar
51PanelMan
The conventional cab F7 F8 trucks and COE F5 F6 trucks have the same front clip (fenders, grilles, lower aprons, etc).
Quick Reply: 51/52 hood length/ new 52 f6
