The fuel bowl heater will short out inside the bowl and blow fuse 22. Just unplug the wire to it and it will be fine. You don't even need the heater anyway. It's the red/green wire on the driver side of the fuel bowl. If you don't unplug it, it will probably blow the fuse again.
Ok, This problem was one of the first things I had go wrong with my truck that i repaired myself. But it has been so long ago I forgot everything I once knew.
I've been working alot and my kids are at the ages that there is alot to do for them. life has been crazy and I'm tired alot. But I've got it good! I'm getting the payments made and my family is the best! How are you doing. Hope god is blessing you with happiness.
