If I had the money, I would run mine twice just for kicks.. would like to run it with stock settings and then turn the bully dog to extreme. But that's $160.
This man's wallet can only take so much
Sent from my SM Galaxy Note 3 using IB AutoGroup
We will be rafffling off 20 runs!!! You can't win one if you don't enter. Sign up. You have a good chance to get a free pass!! Besides. Plenty of stock trucks will make the run. They will give you your base numbers!!
Hahahaha.. I know right? Lmao.
Two provlems.
Passenger side: Danm AC lines won't budge and I can't get the bolt out because of them.
Driver side: shackle to frame bolt just turns on itself and doesn't go anywhere. Ugh! After some googling, it might be the bolt is stuck/rusted on the shackle bushing. Guess I have to apply a lot more heat to melt the rubber and hopefully find a replacement somewhere?
Sux
This project has been a nightmare from the time I decided to do it
