November BS ing (Just a tad early)
#61
That depends on your right foot. Mileage and the weight of your right foot are inversely proportional. You obviously have a light foot. My work van, an '09 E250 with the 4.6 gets about 16-17 at 70mph. But if I slide over to the right lane and set the cruise control to 55 I get 21mph all day long. I just crank up the tunes and chill out watching the "get outa my way" fights going on in the left lane.
#62
I ordered a set of bellowed up pipes today. I would have like to get the ones from riffraff but my funding is very low so I got some from amazon for $170. I do buy just about everything else for the truck from riffraff though and I have a long list of mods to get when ever I'm doing better.
Ever thought about selling the car and getting a crown vic police model. They usually go for under $1500 with only 80k miles.
*yeah I know there are also thousands of idling hours too*
#63
with something that got drowned and dried out.
Sean
#64
Capt'n- Are you in the USCG or a contractor?
Ravage good deal on the bellowed up pipes when I was searching thats one thing my brother made me aware of on 7.3's. I ended up with a V10 for cost reasons but one day will have a diesel.
Greusome- I have not changed a thermostat on those but believe they are on the top of the engine. Thermostat and new coolant should help it out alot. It should be a good runner and save you some money as well. Also can't complain about adding a Ford to the stable.
#65
Yeah I'm not too concerned on lack of power, it won't be used for towing as much as hauling stuff and helping people move. Plus my town does a holiday social and they give out trees for the less fortunate folks and a lot of them don't have a way to transport them. When I had my 88 ranger I helped move trees with them. If I need to pull or tow something I can use the bronco.
As for the coolant issue we were also thinking a head gasket or freeze plug, however the exhaust smells clean, the engine runs well and there was no milkyness in the oil. I'm not quite sure where the t-stat is but it can't be terribly hard to change. It's an auto E4OD. Unfortunately.
#67
You can "rent" it at Autozone.
I also have both a vacuum and pressure coolant test set.
Sean
#68
Gruesome- I believe the thermostats are located on top if they are the same or close to 5.4/ 6.8 they are all at the top. Check out this link.
2004 F250 5.4L Coolant Flush
Capt'n- I have been in pre 9/11 as well. Boot camp in high school in 7/01 graduated 4 days prior. Was in the PSU in Everett, WA and now at Sector puget sound. Reservist been activated twice. Semper Paratus shipmate.
#69
Thanks for the link however, I called the deal off. I drove a friend home a day about 50 feet from their driveway the whole cabin of the car started filling with smoke. It was enough where I couldn't see and hardly breath, after pulling over and shutting it down I let it clear out and couldn't find the source. Eventually I just started it and kept going till I was back at the gas station. Found out 2 wires have been roasted some how.
After that happened I decided to call it off, he is a friend of mine and I didn't want leave him with all these problems.
#71
#75
Capt'n
