Good afternoon Shawn. Good to hear you got your pipes cleaned
72* down this way too You get to test out your new bar yet? (on the truck)
Haven't towed with it yet but it feels like the back end is a little tighter in the corners. Hard to tell because the 350 is pretty stiff and tight as is.
Good afternoon woodchucks and woodchuck imposters. Indian summer here - 68-70 degrees with a warm breeze. Chimney is now brushed out and woodstove all cleaned out. Once the firewood is down cellar I'll be "ready" for winter. Another item off the honey do list.
Sounds productive. I got my used oil pan for the excursion painted. 3 coats of POR15 and one spray can layer of Eastwood chassis black. Hope that keeps the rust away for the next 50 years or so
Those pipes aren't cleaned, yet:-)
Cool. I thought it might be real tight without the camper for some reason. Just the way the hampster was running that day I guess.
Good luck with the other thing
I need to get some more POR-15 next week, so I can get the spindles done. Need to get the bearings, seals,ball joints, and purty new cover ordered, too.
