1990 f250 exhaust
1990 f250 exhaust
hi all, I recently installed a flowmaster 10 series on my truck, and it's not as loud as I hoped. Right now its got a stock cat into a 3in pip in the muffler, then dual 2.5in tips that dump out side by side just in front of the rear tire on the passenger side. The cat on here is pretty damn big and when I ran is with no muffler and only the cat it wasn't that loud. Would putting on a after market free flowing cat on it make it louder? Also what are the advantages and dis advantages of even having a cat? Im going to find out if the truck needs to get air cared and if not I think Im going to take the cat off completely. On the other hand, if the truck does need to get air cared, how can I bypass it, I hear raising the GVW works, but how do I do that, and how do I know if my vehicle is applicable?
thanks for the help,
Jared
Jared
what state are you in? it would be louder without the cat, especially if its the factory cat. if you live in a state that doesnt do emission tests on 23 year old videos, then removing it will only help your performance and get you toward your "louder" goals.
hi flow cats are cheap, will pass emissions, and have little if any adverse effect on performance. it'll sound a little better, but it wont be as loud as if it were deleted altogether.
back before hi flow cats were abundant, i equipped my cat with fittings that matched a "delete pipe" that i incorporated into my exhaust using band clamps, and at emission time it wouldnt take long to swap it out. in the age of inexpensive non-power robbing hi flow cats, the only reason not to run them is for sound or for ease sake in the exhaust sytem.
on
I would check to see if your area doesn't have to pass emissions. Where I am I don't have to and my 88 F150 has no cats into a cheap muffler currently. Not to loud as far as I can tell but I haven't had it running yet (cranking it over sounds louder then stock). A flowmaster usually doesn't get very loud in my opinion usually you will need a glasspack or similar with no cats for a nice loud sound.
We use to have a 93 F250 4x4 with the exact same exhaust set up (routing wise) with just dual thrush tubes no cat. To me it was the best sounding exhaust yet. It sounded like a beast and was still not so loud the cops would harass you all the time. I plan on doing similar set up on my 88 F150.
Trav
Trav
Ya I was originally going to do true duals with glass packs but my truck is converted to propane so it has 4 tanks in total so I figured duals would be too much of a process because of all the stuff that I would have to navigate around. I will see if I need to get it air cared, if not the cat is coming off. If i do have to get it air cared ill try and raise the GVW so bypass it then take the cat off. And if there's no way for me to avoid it ill just buy a free flowing cat from magnaflow or something.
Jared
Jared
