Driving at last
Driving at last
Hey to one & all, finally put my 2001 F250 ambo on the road last Friday.
Bought it back in January (drove back from Melbourne and parked it) as a future tow vehicle for van when the wife and I head off touring etc.
Purchased it mainly for the fully enclosed & central locking back, trayback utes aren't very secure at the best of times but when you're in unknown territory !
So, until we head out, it's replaced my patrol trayback as a work truck. Can't stop smiling the long wheelbase just glides over these lovely regional back roads and that big 7.3 with auto and cruise control
Driving home this arvo through the wheat fields, had to turn on the recently replaced and upgraded CD/Mp3 from "factory radio" and listen Johnny Cougar. As you may have noticed I'm pretty happy with my Effy
Cheers Russ
Cheers Russ
Found it on 'g' tree at dealer in Melbourne. Was looking for a 250 and they were all dual cab 4x4, $50k and upwards for '04 onwards with 250-300k mileage. Only paid half that !
I've put some pic's in my garage on here, haven't got enough access on here yet to post pic's. Still had a lot of reflective tape in the back then. They're stickier to remove than dung to a blanket
Cheers Russ
Cheers Russ
I looked at the truck you got, nearly brought it but got mine. It's an early super duty that was bought in and converted for ambos! It's not a Brazilian built one! There is a few differences but nothing major, little things like the dash vents and I think yours still has a foot hand brake?. Will be an early forged rod engine too!
Yep, body was built in Brisbane. ID plate shows it was built in April 2001, also says "vehicle development corporation". Maybe where they build special order vehicles.
Sorting out the load sensing suspension what a bit of an ordeal until we found a third battery in a compartment in front of the right rear wheel !
I don't really need a 4WD as the wife has a 4WD X Trail, so just a tow vehicle for our 25' van. The enclosed rear body is another reason it suits us for securing all the equipment while were on our travels.
Removing that reflective tape has been a nightmare, worse than dung to a blanket
Is the tape on the outside? I know 3M make a buffer disk especially for buffing pressure sensitive vinyl off vehicle paintwork.
Inside I'd try eucalyptus oil to soften and remove the adhesive if you can't buff it off.
http://solutions.3m.com/wps/portal/3...beRJ5GMFSMV0gl
Thanks for the hint and the link Brad. The top reflective layer came off resonably well but lifting the backing was another story. Tried thinners, turpentine, metho and water, plastic scrapers with steam (the handy little "shark"). For the glue, turps for a bit of a rub to soften the glue, then the dry part of the rag to roll it up like a drying silicone ball, then turps to remove the black smear. Very time consuming, not to mention chips out of the super thin paint
I'm in regional, semi remote, rural Australia, so, unfortunately, shops (stores) only stock fast selling lines/products, the basics that's it.
Hey Russ, allegedly there is a wiring loom under the dash that some brake controllers will plug straight into. There was a thread on it in the US 1999-2003 forum.
See: https://www.ford-trucks.com/forums/5...ontroller.html
I've never had the pleasure of fossicking around for the plug as my effie had one already fitted courtesy of the PO.
Thanks Simon, I trawled the site a week or so back for that info, thanks for posting the link, makes finding the info again easy.
I've yet to pull the plate out from under the dash, been busy connecting up some rear vision wiring and cameras. Someone said the open plug could even be in the centre of the truck. I'm waiting for the ford connection plug to hook in so I don't have to cut into the existing wiring to connect the Redarc controller.
Crazyotto1
68
02-25-2015 12:50 PM
BigB
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
05-07-2007 09:13 AM
BigB
04-17-2007 07:50 PM
