Overdrive transmission question - Ford Truck Enthusiasts Forums
Old 10-30-2013, 05:51 PM
dcagnolatti's Avatar
dcagnolatti dcagnolatti is offline
dcagnolatti is starting off with a positive reputation.
So my '59 is at the transmission shop waiting on a complete rebuild. When I bought it, I was told it was equipped with an overdrive transmission, but the cable had not been hooked up. I asked the transmission shop to see if they could get the overdrive working. It would really improve my gas mileage.
Has anyone else been through this before? Have any insights, do's and don'ts, words of wisdom about the overdrive feature on these 3 speeds?
Old 10-30-2013, 08:29 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
I hope your shop has someone with experience with these overdrives units
( read one of us old guys ). Besides the mechanical part there is an electrical circuit with a relay, kickdown switch, solenoid and governor. Many of these parts are getting hard to find and are expensive when you do. When working properly they are great, I've used them in several passenger cars and have one in my F100..
Old 11-02-2013, 12:54 AM
dangus dangus is offline
dangus is starting off with a positive reputation.
You could get away without some of the electrical stuff... it's designed to kick down into normal drive when you floor the gas. But it wouldn't be too hard to adapt a common relay and a momentary contact floor switch (starter? horn?) if you don't have the originals. If you need the lockout cable assembly, those may still be available from Ford truck specialists. (I bought one around 1990, although the plastic handle looked like a different type of plastic than would have been used originally.) I only took one test drive with the O/D transmission, since something went wrong when I reassembled it and the cases didn't seal properly. That particular transmission wasn't from a Ford, and has since gone to the scrapyard. (I did save the solenoid and governor.) I scored an allegedly Ford 3 speed/OD from a swap meet, but haven't tested it out yet.
For a working truck, it might be wiser to install a truck 4-speed (with the granny 1st gear), or spend the bucks for a modified bellhousing to fit a modern overdrive transmission. I've encountered a couple of hills that couldn't be climbed with a loaded truck in 1st gear with a light-duty 3-speed. One hill could be avoided; the other I backed up and took a run at.
Old 11-02-2013, 01:08 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Recent discussion with some links to parts etc. OD ratio was .70 or .72, allowing a shorter rear axle such as 3.89 or 4.11 etc or even 4.89s.
http://www.ford-trucks.com/forums/12...a-cruiser.html
C6 to overdrive conversion msbhvn Offroad & 4x4 27 11-16-2016 06:06 PM
transmission slips in overdrive Adrian Adams 2004 - 2008 F150 1 03-10-2015 11:43 PM
Overdrive a mistake? F-350 in Buckhead 1999 to 2016 Super Duty 14 08-24-2010 06:28 AM
04 F-150 OD tfink3 2004 - 2008 F150 7 01-06-2010 04:34 PM
overdrive transmission tomjohnbales1 1973 - 1979 F-100 & Larger F-Series Trucks 17 12-02-2006 03:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
