starter drive gear stripped too much?
Almost any auto parts store can get you one. Rebuilt starters usually don't include the Bendix drive that has to be bought separately.
It looks like NAPA has them $61.00
Mini starters are rather expensive from what I remember and I'm not sure if I have seen one for our old Fords that have the three mounting holes..
I've come across some online for around 259.00
http://www.robbmcperformance.com/pro...ordyblock.html
RobbMc Performance Products - Ford Y-Block Starter
Pastor, Those starter drive teeth don't look good to me at all. I would replace the drive assembly.
But I have not read from anyone telling you to check the flywheel ring gear. If the ring gear has some teeth missing or badly damaged, most any starter might not engage to turn the engine over.
My advice would be to check the ring gear out completely, all the way around. If you find it bad, it can be replaced on your existing flywheel, by an automotive machine shop.
If, as you said, there are lots of sparks when the starter is running, you might need new brushes, and maybe need the armature commutator turned true again. Check the starter end bushings for slop too. It could be the armature is jumping around inside the starter housing causing the brushes to arc like that.
Hope this will help you.
Aloha, Tony
Aloha, Tony
Thanks...the sparks came from the top post when I tapped my jumper cables to it. Nothing came out the back or anything. I'll inspect the ring gear(motor still in truck) by painting a tooth and turning it bit by bit and see if they are all there? I get a clear view in the starter housing. I was thinking the starter drive looked a little worn myself
http://www.ebay.com/itm/56-62-FORD-MERC-REBUILT-STARTER-W-WARRANTY-NICE-1-/360771110147?pt=Vintage_Car_Truck_Parts_Accessories&hash=item53ffa24503&vxp=mtr
http://www.ebay.com/itm/1956-1957-1958-FORD-V8-1-1-2-TON-TRUCK-STARTER-REBUILT-/380749154954?pt=Vintage_Car_Truck_Parts_Accessories&hash=item58a66b0a8a&vxp=mtr
http://www.ebay.com/itm/1953-1961-starter-drive-ford-thunderbird-tractor-truck-mercury-marquis-more-/360778618593?pt=Vintage_Car_Truck_Parts_Accessories&hash=item540014d6e1&vxp=mtr
http://www.ebay.com/itm/ACE-3-553-480367-A3257-Starter-Drive-Bendix-Ford-Car-Truck-Tractor-1954-1964-/271190033589?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f242f84b5&vxp=mtr
Here's a few different possibilities from good 'ol Ebay!
