Engine Miss
If it's not in the wiring, check your oil. I know mine run low on me a few months ago and it developed a wicked miss. It would choke out, lose all power and throw white smoke like it was going out of style. I guess my theory is irrelevant since you're getting codes. But...it's just a thought. Wonder if it could be CPS related also? Just spit-balling, here. Good luck!
I did, Early on before I replaced any parts. It was dry and had no burnt smells. The harnesses and valve cover gaskets didn't look burnt of smell burnt either. That is what is making this so difficult. Those 2 clys failing at the same time to me would rule out the injectors, so I cant come to any other conclusion but the IDM? If I knew of someone with a similar truck I would swap it out as a test.
Davish
21
04-13-2019 04:54 PM
75Three90
03-16-2013 09:24 PM
captgann
12-22-2010 09:55 AM
johnsonswamp
10-23-2008 06:32 PM
450rutmaker
03-30-2004 07:55 PM
