351W headers in a 1978 F250 4x4
Old 10-29-2013, 07:07 PM
BossFan's Avatar
BossFan
BossFan is offline
I just had my buddy put a set of GT40 heads and a cam that Conanski recommended in the 351W that is in my truck. I figured that it would also be a good time to swap the headers since the ones in there are pretty rusty. After reading every thread I could find on this forum about 351W engines in a 'Dent it seems that nobody makes headers for these truck/engine combos. But my truck already had a set of headers. Albeit old and rusty, in it. Surely there has to be some application that works? A guy on eBay was selling a set of OBX headers that he guaranteed would fit. Heck, even the OBX website says they will fit. But they don't. Not even close. Here is a pic of the OBX header and the one that came out of the truck. Has anyone found a set that works? I would blast mine and have them coated, if I didn't think they would disintegrate.
Old 10-29-2013, 07:14 PM
BossFan's Avatar
BossFan
BossFan is offline
This Hedman Header is the closest set I found that looks like what came out of my truck.
Old 10-29-2013, 07:24 PM
V10man's Avatar
V10man
V10man is offline
Those hedmans are for the 351M/400 not a 351W. Will a 302 set work?
Old 10-29-2013, 07:31 PM
BossFan's Avatar
BossFan
BossFan is offline
Thanks for that clarification I've been scouring the Internet looking for images of 302/351 long tube headers (the ones in my truck are clearly long-tube) just to see if I can find something remotely close.
Old 10-29-2013, 07:43 PM
BossFan's Avatar
BossFan
BossFan is offline
Theses are for an early Bronco with a 351W in it. A little closer.
Old 10-29-2013, 07:59 PM
BigBlockMan's Avatar
BigBlockMan
BigBlockMan is offline
What about using a set of shorty headers?
Old 10-30-2013, 06:13 AM
gnwalker's Avatar
gnwalker
gnwalker is offline
Dougs 302/351 shorty headers from Summit are the only ones I could find that fit my 78 f250 4x4 4speed. I've tried a lot of headers over the years and they were the only ones to fit. Maybe long tubes for a different application could work with a little heating and bending
Old 10-30-2013, 12:56 PM
hivoltj's Avatar
hivoltj
hivoltj is online now
302 ones maybe should work. They will sit about an inch higher
Old 10-30-2013, 09:37 PM
BossFan's Avatar
BossFan
BossFan is offline
Do you know which part number?
What's the performance difference between long tube and shorty headers?
Old 10-30-2013, 10:26 PM
gnwalker's Avatar
gnwalker
gnwalker is offline
Not sure of the part number. It was 6-7 years ago. It should only take a few minutes on summit's website to find
Old 10-31-2013, 11:50 AM
gnwalker's Avatar
gnwalker
gnwalker is offline
I checked summits website and couldnt find the headers. I'll check the pertronix website later today
Old 10-31-2013, 12:38 PM
BossFan's Avatar
BossFan
BossFan is offline
I called the tech line at Summit. They were a huge help. The headers that came off my truck are old Hooker headers. If you go on the Summit website, and type in 12502FLT, you will see the Flowmaster headers. Somebody bent the lower part of the tubes on mine for clearance issues, but these are definitely the headers that came off my truck.
When I told him it was a 1984 351W engine, he said he looked up headers for the year of the engine rather than the year of the truck and that's how he found these.
I am going to order these and will let everyone know how the install goes.
Old 10-31-2013, 12:41 PM
BossFan's Avatar
BossFan
BossFan is offline
Originally Posted by BossFan
I called the tech line at Summit. They were a huge help. The headers that came off my truck are old Hooker headers. If you go on the Summit website, and type in 12502FLT, you will see the Flowmaster headers. Somebody bent the lower part of the tubes on mine for clearance issues, but these are definitely the headers that came off my truck. When I told him it was a 1984 351W engine, he said he looked up headers for the year of the engine rather than the year of the truck and that's how he found these. I am going to order these and will let everyone know how the install goes.
It was the Tech Line at Petronix that helped me, not at Summit. Fantastic customer service even though they don't carry the Flownaster headers!
Old 10-31-2013, 08:37 PM
Vadis's Avatar
Vadis
Vadis is offline
Thanks a lot for posting what you found out BossFan
I was planning on swapping a 351W into my '79 F150 4x4 and until now I could never find a 100% answer for headers for this swap (besides expensive custom ones).
Reps sent!
Old 05-05-2014, 09:23 AM
BossFan's Avatar
BossFan
BossFan is offline
Vadis,
I was doing more research and when I looked closer, the 12504FLT is closer (exact?) to what I have on my truck. The photos look exactly like what is on my truck. I am planning on ordering a set and will let you know how they fit.
http://www.summitracing.com/parts/bi...view/make/ford
Quick Reply: 351W headers in a 1978 F250 4x4
